Ipod integration
Old Jan 11, 2012 | 12:39 PM
tomthumb's Avatar
I just bought a 2008 e60. I was told that I could not get a center console USB retrofit. The dealer told me that I could get an Ipod system connected through my glove box. Does anyone have any advice on this set-up?
Old Jan 11, 2012 | 01:38 PM
Mobmatrix's Avatar
Do you have a cd player in the glovebox ?
Dó you have navigation professional ?
If yes and yes, you could use a product called Gateway 500. I guess its from Dension
Its pretty easy to install, i guess there are som guides under do it youself
Old Jan 11, 2012 | 01:52 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
You can also get OEM ipod interface kit, this kit is only for Ipod and has no other media input or output unlike Dension or Dice. You will also need some coding assuming that your car is pre-wired. Here is the kit;
Old Jan 12, 2012 | 05:56 AM
zinchuk77's Avatar
I have been down that road also. I did lots of research to get a unit called dension gateway 500. It can be hooked up in the glove box wether you have navigation or not, as long as you have a cd changer or cd changed prep , meaning its prewired for cd changer. I had dension unit hookup up in 2 of my e60s. One had navigation and one did not. Dension is good because besides having ipod connectivity with all text support and browsing capabilities you can also hook up Bluetooth audio, ish drive, it has aid in, and you can get video on your screen too. Another product that does similar things called mobridge , check that out too
Old Jan 12, 2012 | 05:59 AM
zinchuk77's Avatar
I meant to say it has usb drive connection and aux in
Old Jan 12, 2012 | 12:40 PM
tomthumb's Avatar
Does the Dennison work if you have a sattelite radio installed?
Old Jan 12, 2012 | 03:05 PM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
I bought the OEM ipod Integration kit 2 years ago to have it work with my current ipod nano (3rd generation). For Christmas I received a (5th generation) nano but it won't charge when I plug into the cable from the car. Anyone else have problems ipod not charging when you plug it into the car? The guy at fry's told me he's heard of this problems before with the OEM ipod kit. I have a 2006 E60 530i
Old Jan 12, 2012 | 05:01 PM
BlaSTiWi's Avatar
Yes, I installed my Dension GW500 together w/ Sirius Sat radio myself.
Old Jan 12, 2012 | 05:02 PM
BlaSTiWi's Avatar
Apple changed the pin configuration ... if you do the search you'll find that you need and adapter i.e. by Scosche.
Old Jan 12, 2012 | 07:35 PM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Thank You I'm searching now
