Ipod Connection for 2004 models
My Ride: G30 M550i
Model Year: 2018
I'm a bit foggy on all the various compatibility dates, etc. these days but I think you can get it only if you have a CD changer or the pre-wiring for it. You're not able to get the newer USB/iPod interface, just the MOST bus interface that sort of emulates the CD changer to the car...
My Ride: E90 M3
Model Year: 2011
Ethan, it is. I had it installed some time ago in my Jan '04 build 545, works great. Can be done on cars with or without NAV. 6-Disc changer also not a requirement. If you don't have the changer, the cost will be a bit higher for the additional wiring harness needed to make the connection. The attached link to a PDF file explains most of it...
http://forums.e60.net/index.php?act=attach...st&id=52767
TexaZ3
05-06-2015 09:54 AM
