Intermittent Starting fault on 545i Touring.
My Ride: BMW 545i Touring Fully Loaded
Hi There,I am new to this Forum and was wondering if anyone can offer advise on My BMW 545i Touring 2004,Sometimes I turn the key and nothing happens at all,no click or anything,My foots hard on the brake pedal but still nothing,Then you call out the recue as soon as the Guy get here I turn the key and it starts,He checks it on the computer but nothing regestered I take it to BMW they could not find fault.Now wife saying she does not want to go out in it because it has done it several time when she drove it.Does any 545 owners have a similar thing?
My Ride: 2004 525i
Engine: M54
No power at all? or just no start? I've had the no power at all issue with my '04 525i several times. I think in my case there's a loose power connection somewhere in the line to the battery. I'm not certain due to the fact that it happens maybe once every other month. The reason I think it's a loose connection is I've used the FOB to unlock the car, gotten in the car, put the key in the ignition and nothing works, nothing turns on, and it of course doesn't start. I'll take the key out and retry but same result. I'll open my driver door and close it and everything is normal. I think the closing of the door is causing so much vibration somewhere that it causes the loss of power in the car. I could be wrong.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I had this issue once. Turned out to be the starter. It was at the dealer for 2 weeks and they could not find the issue. They updated the software and gave it back. The next week the same thing. When I took it back I told them to change the starter. They swore to me that it was not the issue and I told them to change it anyway. What do you know 3 years later still no issue.
My Ride: 1995 540i, 2005 545i
Model Year: 2005
I hope to steal from your post for a resolution, outside of dropping the engine and removing the right exhaust manifold to get to the danged bolts...
Rod
