5Series.net - Forums
-   -   INPA Error Codes (https://5series.net/forums/e60-discussion-2/inpa-error-codes-133472/)
kskane Jun 11, 2013 11:21 PM
INPA Error Codes
Hi, I am trying to find out what the error codes that I got from INPA mean. A while back while searching for another error code, someone directed me to this link.
BMW Hex Codes pdf free ebook download from www.bimmerfest.com
It has a list of code for all different engines and I am not sure if the code for my car mean the same in another car.
I have 2004 E60 525i M54 engine with Auto Trans and I am trying to find out what does the error below mean.
A43E
ABCA
281E
5F56
Thanks in Advance.
kskane Jun 13, 2013 06:30 PM
1 Attachment(s)
Further digging into INPA showed me A43E details, image attached. Anybody know what that means?
tonyb635 Jun 15, 2013 06:00 AM
1 Attachment(s)
I wish I could locate them too. I have all sorts of OBD info but I also get similar codes and just can't quite figure out what they are.
cmyachtie Jun 16, 2013 11:59 PM
A43E
ABCA
281E
5F56
Thanks in Advance.
My guess would be bad connection between pin#72 of the connector between the KMB and AL modules?
HTH
kskane Jun 17, 2013 04:30 AM
HTH
Thanks cmyachtie, What is KMB and what is AL modules, and where does the pin72 sits?
cmyachtie Feb 5, 2014 02:12 PM
SORRY for the late response, guess the email notification did not get to me or I missed it , anyway the KMB is you kombi or instrument cluster and the AL is you light module and on BMW-Planet.com | you can find all this, including the pinout of the connectors.
Now that being said, I am currently myself trying to get to the bottom of the 5F56 error as it appears in my DSC module and am doubting my suggestion from before as I am at a loss what it would have to do with the DSC error/fault code I now have experienced.
kskane Nov 1, 2014 05:06 AM
1 Attachment(s)
Attached is the wiring diagram for 'Body Basic Module' for the KBM, does anyone know where the PIN72 error could be related to A43E error code?
F-Tar Jul 19, 2015 07:48 AM
Same issue here... Did u solve it?
F-Tar Jul 26, 2015 11:33 PM
I dissasembly mirror passenger side and did a Clean-up. All good.
