independant heater
I think it just blows outside air into the cabin... so whatever the temp the air is outside is what you'll get. Its for cooling not really heating... or like 535 said... unless you have a engine block heater.
Originally Posted by E60525d' post='216757' date='Dec 29 2005, 03:34 PM
On the idrive climate settings i have an option for switch on times. Is this hot or cold air i can program the car for?
In the wintertime it should give all the warmth the car can give (which isn't much in a diesel)
and in the summertime all the cold it has (which isn't much either).
For optimum comfort you should have a remotedly controlled diesel warmer (I think BMW has
one to offer one, retrofits are available e.g. from Ebersp?cher).
My Ride: -04 530D
Skaffa
Skaffa
[/quote]
What kind of stand-by heater do you have? BMW optional heater, retrofitted Webasto/Eberspr?cher or a electrical heater?
My Ride: F02 LCI Individual
Model Year: 2013
It is to get air from the outside into the car. Meant to cool down the interior on hot days when you leave the car in the sun and know when you return.
If you have the independendant heater you can also get warm air in the car. This can also be done by remote.
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
FWIW, I have found that holding the key remote button down, as I walk toward the car on a hot day, thereby letting all the windows down, does a fine job of expelling hot air. By the time you get to the car, and maybe pull out of your parking spot, you can turn the A/C on.
Cheers,
Ray Hull
Cheers,
Ray Hull
[/quote]
Exactly, this works well for me in the hot Florida summers (thats 8 months worth for u yankees )
I can get this to work from about 40 steps from the car so it has easiliy released that blast of hot air.
