Sponsored by:
Sponsored by:
brake pad shift noise normal?
Old 04-13-2013, 06:29 AM
doughboy540's Avatar
My Ride: 2010 BMW 550i m sport lci
Default brake pad shift noise normal?
2010 550i m sport when parking mostly and changing direction wheather its fwd or reverse and the brakes are lightly applied it sounds like the pads shift and make like a medal on medal tap I drove with the tech @ bmw brakes arent due for another 30k and tells me its normal....WTF!?I work for a Toyota dealer and those shitboxes dont even do that nor does a regular car... what do you think is the dealer B.S ing me?
Old 04-13-2013, 04:54 PM
RIHI's Avatar
My Ride: BMW
Check with another dealer. I haven't had that issue and I do my own brake jobs.
Old 04-14-2013, 04:28 PM
Tooch01's Avatar
My 2008 550i does this as well and have taken it to 2 dealers and both confirmed that it is not normal and is exactly what you mentioned, pads shifting in the calipers when brakes are pressed. I bought my car a few months ago and did not hear it until windows were down, and its quite annoying, although both dealers said it is not hurting anything but if I wanted I could replace with OEM pads to resolve the clanking/clicking. I'm sure as I drive it more in he spring weather with the windows down ill probably ending up doing that even though I have about 25k left per the sensors.
Old 04-14-2013, 04:41 PM
So.what does the dealer say is the solution to get rid of the noise?
Old 04-14-2013, 05:23 PM
Tooch01's Avatar
Replace the pads. They tried to adjust the pads to stop the noise but said basically they are just a hair to small causing the shifting in the calipers.
Old 04-14-2013, 05:54 PM
So in other words I'm stuck with sum sort of noise no matter what?
Old 04-15-2013, 02:18 AM
Tooch01's Avatar
No, you can change them now vs later and that should eliminate the noise.
Old 04-15-2013, 12:10 PM
LessIsMore's Avatar
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
I have the same issue. OEM BMW pads. Never serviced during my owership of the car, still has several thousand miles left on them (per computer/diagnostic screens in iDrive). It only occurs here and there, I'd say less than once a week do I notice/hear it.
I DO NOT think it is "normal".
I DO think new pads would solve it.
Old 04-15-2013, 12:48 PM
car is still under warranty so ill go to them and make em put a new set in I also dont think in any way, shape or form this can be normal....
Old 04-15-2013, 12:58 PM
Shlooky's Avatar
My Ride: 545i
I'm glad someone brought this up!!
04 545i here and I have the same issues too, it sounds like metal cracking sounds, which occurs when i have the steering wheel cranked either way while backing up into a parking spot.
Annoying as heck since this is a BMW we are talking about.
Will replace with OEM and see what happens.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
Jorgemorascv
05-17-2015 07:06 AM
TexaZ3
05-06-2015 09:54 AM
Sakru
03-26-2015 09:26 AM
08-12-2003 11:41 AM
Quick Reply: brake pad shift noise normal?
