Increased Battery Discharge Warning
Old Apr 5, 2010 | 05:43 PM
johnhh's Avatar
My 07 550 was not used for 3-weeks. Today I went to start it, battery seemed very low but then it came to life. I got it started but got "increased battery discharge" warning and the clock will not stay set.
Does anyone know the cause or fix? The car is not driven very often and sits for extended periods of time (2-3 weeks). Thank you.
Old Apr 5, 2010 | 05:45 PM
PraiseTheLowered's Avatar
lol you have a dying battery
a new battery plus driving the car will fix it
Old Apr 5, 2010 | 05:56 PM
hinckley's Avatar
This has happened to me since I got my car new. It has nothing to do with a dying battery. I travel frequently and often return with exactly these symtoms. I've brought it to my dealer more than once. They tell me that I don't drive the car enough (23K miles in three years). Go figure . . .
Old Apr 5, 2010 | 06:03 PM
that might not be true in your case but he doesnt drive for 2-3 weeks sometimes
his car might also not be going into sleep mode properly either
Old Apr 5, 2010 | 07:10 PM
Victory's Avatar
I had a similar problem. The solution for me was to pick up a $8 trickle charger. I use one of these on my Grand National (which stays parked most of the time) and now I use one on my 550 as well. They are simple, work like a charm and pretty much disposable if they go bad - although I have one I have had for 3 years and it still works fine.
Trickle Charger
Good luck.
Old Apr 5, 2010 | 07:12 PM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
+1
Sounds like your battery is at the end of it's watch. A battery tender might be a good investment for a car that sits weeks at a time.
Old Apr 6, 2010 | 08:58 AM
juris335's Avatar
My Ride: BMW 535xi
Lots of info, on this site, re: this battery problem. I solved the problem. See the below link. Good luck.
http://forums.5serie...__fromsearch__1
Old Apr 7, 2010 | 02:08 AM
nick1981's Avatar
Had this issue when I left my 530 at Heathrow for 6 weeks. Funnily enough I didn't get the warning doing the 20 miles to home, but had it daily from the next day onwards. To get rid, I did a quick 40 mile roundtrip to work and back, and sure enough the warning disappeared after that.
One thing I did notice - sometimes, the Bluetooth gets "confused" with my phone and thinks its in a call. When you turn the car off, the display remains on, the car doesn't go to sleep, and worst of all in teh phone menu you can not hang up on the alleged call in progress. Turning bluetooth off on your phone doesn't work either, so to get it back to sleep you may have to turn bluetooth off.
Old Apr 12, 2010 | 01:41 PM
johnhh's Avatar
Purchased a battery tender - seems to be doing the job.
Old Apr 13, 2010 | 10:43 PM
nevrev73's Avatar
My Ride: 2008 530d M sport
check IBS lead... thats what it was on mine... you need to drive / start it regularly otherwise it will go flat, just doesnt hold its cgarge forever as so complicated electronically
