Increased battery discharge
Old 10-12-2006, 03:27 PM
denuyl's Avatar
mine displays this message once in a while; car (01-2006 550) was at the dealers a month ago because of it and they replaced the entire steering column (at least this is what they said:"the carcomputer readout says this has to be replaced, better sure than sorry") needless to say the warning "excessive battery drain" has allready showed up again
Old 11-03-2006, 03:56 AM
drjochen's Avatar
My Ride: 530i 6 speed
I had this message for the first time this morning. The car has lost all data (time, fuel comsumption, the trip computer had reset etc.).
The car was in the garage overnight. No ddors open, no interior lights on.
I thought the new car would be better in quality, but then I might be wrong again....
Old 11-03-2006, 04:54 AM
dlevi67's Avatar
Clutching at straws - but was it very cold overnight? In a garage it should not matter too much, but...
Old 11-03-2006, 05:15 AM
drjochen's Avatar
It was 34F, but in the garage it was over 50F. Now the car is sitting outside in the work parking lot - lets see what happens when I go home...
Old 11-03-2006, 06:06 AM
dlevi67's Avatar
It won't be temp, then. It was 28/30 over here (South-East UK), and I certainly had no problem, but the night temperature went from low 50s to low 30s quite suddenly here, so I thought it might have done worse in the US.
Old 11-03-2006, 06:35 AM
alexB's Avatar
My Ride: delivered 5 sep 06: 520d E61, silver gray, dakota truffle brown, comfort seats, aluminium, PDC, nav pro, pro spkrs, 124 rims, auto a/c, comfort access, anti d mirrors, side airbags, int rem ctrl, roll blinds, glazing, green band, light pack, storage comp
I had exactly the same but has happened after the first start up in the morning. Pretty much I started and run and after few miles I stopped. When I went back to the car after an hour or so nothing was working, I had to open the car with the key, the CA not working, alarm neither, inside all data's gone. Fortunately started up and after the same driving I stopped at home and shut down. Few minutes later went back to the car and alert message was gone....
Tried ask the dealer........... go figure........ :thumbsdown: :thumbsdown:
Old 11-03-2006, 07:38 AM
drjochen's Avatar
Here is the error message I had this morning. I am kinda scared not to go back to my car.......... :'(
It says "turn off unnec. ... consumers - but I had nothing on....
Old 11-07-2006, 02:13 AM
UrbanDriver's Avatar
The problem I had has now been fixed. Water was coming in to the boot through a faulty seal around the fuel cap. This water was then sitting around the battery and had caused some corrosion on one of the electrical joints. All sorted and dried now with various items changed over.
No errors for me anymore.
Old 11-07-2006, 07:05 AM
fantomas's Avatar
My Ride: 2005 525d Mystic Blue Business Line
I have this message each time I let my mobile phone in charge for more than one hour with the engine stopped. How a mobile phone can discharge a diesel car battery ? If your car starts promptly, you don't have a real problem. Some other battery drain problems were fixed in Progman 20 or later.
Old 07-06-2007, 11:36 AM
KeroJet's Avatar
I just started getting a similar message on my LCI 525d. After some experimentation, it message displays when I lock the car and it sits for 30 mins or so, but everything seems fine if I leave the it unlocked. So far, I have not had any difficultly starting the car. I suspect I either have a faulty sensor or something is not right with Comfort Access.
Anyone have any other thoughts?
Quick Reply: Increased battery discharge
