Increase Battery Discharge and Clock Not Staying Set
![Unhappy](https://5series.net/forums/images/icons/icon9.gif)
I have been getting an alert regarding low battery level and increased battery discharged for a few weeks now.
In addition, the clock is refusing to stay set after turning off the car.
I thought it was just a bad battery and so replaced the battery last night but to no avail.
So what else could be causing this problem? Alternator? Messed up computer? Or?
Ever since I put the new battery in, I keep getting a window is jammed icon showing.
I do not have an OEM battery.
Last I was at the dealer, the service manager noticed that it was not OEM but he said it was fine.
Update:
I went out to my car to check on it again and everything is working fine and clock is still set.
The window jammed icon appeared but then I rolled down all the windows and back up and it went away.
My Ride: 2006 550i, 6 speed manual
Experienced the clock not staying set issue prior to my battery dying recently. If your battery is new either it's bad or there is a voltage regulator problem.
hate to ask a dumb question but if you didn't register the battery doesn't that throw a code? as i'll be due for a battery soon i can't see spending $600 for a dealer battery
