IDrive will not recognize hard drive
#31
My Ride: LCI E60 520d SE Manual, Jet Black/Natural Brown/Light Poplar, Auto A/C, Elec Front Seats+Lumbar & Driver Memory, SCA Doors, Thru Load, Auto Dim Folding Mirrors, Adaptive Xenons+High-beam Assist, LDWS, USB Audio, 244 wheels+RFTs (until worn) & S-S Spare
Originally Posted by jfisher08' post='490496' date='Nov 6 2007, 12:38 AM
Update
Tried bob.a's idea and purchased a 1.8 drive and a portable enclosure so far it is working great, finally. One question do I need to unplug the drive every time a get out of the car since it stays on?
Thanks for everyone's help and hope this helps others not have to go through what I did.
#32
I've tried three different external USB hard drives and none of them work in my car - and this includes ones which other people report as working fine elsewhere. Bob - you are in the UK?? External hard-drives are really cheap and easily available, I'm not sure why you can't find them.
Google ... "external usb hard drive uk price". Take your pick from the hundreds that appear!
I bought all of mine from here ; http://www.scan.co.uk/Products/Products.AS...;Thumbnails=yes
The latest one I tried was the Fujitsu Handy Drive. Others here reported it as working fine, on mine it doesnt get recognised by the car.
I also have problems with large USB sticks - I am sticking with my 4Gb one which seems to be working ok, albeit the occasional "jump back to FM" issue.
#33
My post today was intended to be specifically about 1.8 inch low current hdds, preferably the new 3600 rpm "entertainment drives" which impose much lower startup loads than 2.5" data types like HandyDrives.
I'm also concerned about the enclosure. USB power control is quite complicated, so depending on the extent to which the relevant sections of the USB Standard have been implemented (by both enclosure designer and BMW), there's a great deal of scope for incompatibility and variability in this situation; but do I think a lower consumption hdd should be less troublesome than a higher consuming one, so I'm hoping a "known good" 1.8 inch enclosure/drive combination should be a good bet. Bob
#34
My Ride: 2008 535i Space Gray Active Autowerke performance software, custom exhaust, AFE intake
Here is the info on the drive and enclosure got both from ebay
Hard Drive:
Toshiba 1.8" ATA Laptop Hard Drive 2MB Buffer ZIF connector 60GB
Enclosure:
SquareTrade ? AP6.0
Hi-Speed USB 2.0 EnclosureFor 1.8" Hard Drive with ZIF Connector
Product Features
This external ultra slim enclosure is designed for 1.8? ZIF hard drives, either Toshiba or Hitachi . This tiny portable device provides maximum durability, flexibility and portability with standard USB 2.0 Hi-Speed interface. Just plug the USB cable into any notebook, desktop, or Macintosh with USB ports and you have instant connectivity. With built-in hot swap technology, you can connect and disconnect the drive at any time.
Slim Aluminum case
Plug and play
Stable and Quick
Large Storage Support
No External Power Required
FEATURES:
USB 2.0 and USB 1.1 standards
Chipset: Prolific PL2506
Windows 98/2000/ME/XP/2003/Vista, Mac compatible
High speed data transfer up to 480 Mbps
Suitable for 1.8" hard disk with ZIF connector (either Toshiba or Hitachi)
Full Aluminum Magnesium alloy Material
Two colour LED indicator
Size: 108mm x 60 mm x 10 mm
Hard Drive:
Enclosure:
SquareTrade ? AP6.0
Product Features
Slim Aluminum case
Plug and play
Stable and Quick
FEATURES:
#35
My Ride: 08 535xi
Bumping up an old thread...
Seems the best thing to do is use any 4G or newer ipod in disk mode. I have my files encoded at Lame 320 VBR and they sound amazing. I'm using a 5G 60GB ipod with the ipod cable plugged into the usb port. (I'm not using the BMW Y cable, that cable ports the audio through the analog aux in port) Using the standard ipod cable you have full digital transfer to the audio system in the car, and like I said, it sounds amazing.
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
