iDrive stopped working after car was in for an oil leak
Old 12-16-2014, 03:47 PM
deansimpson's Avatar
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint. Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels. Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
Default iDrive stopped working after car was in for an oil leak
I have a 04 545i with 66,000 miles.
I took it in for an oil leak and it sat there with the battery disconnected for several days.
After completing the repair I got it back and the iDrive, stereo, nav and everything related is dead.
My battery, alternator, IBS and negative cable are all very new from my last nightmare.
Everything worked perfect when i took the car in.
What the hell could've happened??
I can't imagine they could've done anything to blow the CCC modual.
Any help would be appreciated!!
Old 12-16-2014, 04:38 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
fuse?
Old 12-16-2014, 05:23 PM
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
Ouch, I hope it's nothing serious!
Since owning a car that can be expensive to fix, this is the main reason I try to fix everything myself.
I am so glad I found HealthServices (one of the reputable members here) to change my transmission filter and such...
By the way, make sure the battery post(s) is properly and tightly connected. Is the battery fully charged?
Best of luck to you!
Old 12-16-2014, 06:52 PM
Originally Posted by KyleB
fuse?
Have not checked the fuse yet. Will do that tomorrow.
Thanks.
Old 12-17-2014, 03:13 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Bentley is showing the CCC fuse located in the glovebox, F34 position.
Also, check your MPM on the trunk floor, make sure you didn't take on water.
Good luck, don't forget to post up when you get it resolved.
Old 12-17-2014, 04:01 AM
wcr3d's Avatar
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
Is there a reason you're not taking it back?
Old 12-17-2014, 07:28 AM
Thanks!! Will do.
Old 12-17-2014, 07:31 AM
They spent an hour trying to figure it out.
They did some research and told me to bring it back today for some reset that takes two hours.
I think this is out of their league.
I still need to check the fuse. Hoping that's it!!
Old 12-17-2014, 09:13 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
There might be a separate fuse on the back of the CCC drive too. I've had mine out before, but can't remember for sure if there is or is not.
Old 12-17-2014, 07:24 PM
Fuses are all good.
Car back in the shop all day and they can't figure it out.
The battery was disconnected before any work was done.
Reconnected when work was complete.
Everything was working prior. How could this be??
Quick Reply: iDrive stopped working after car was in for an oil leak
