iDrive software update??
I want to update the software on the idrive. It just seems like its getting slower in response time when i want to turn down the volume or change radio stations, browse thru menues, etc...
is there a way or a tutorial that i can do it instead of taking the car to a shop? It sounds like I need the software "Autologic" to but other than that I would need the update package. Any help would be appreciated B) |
Or is there anyone in the LA/OC/IE area that do coding/updating software wise?
you need an ICOM cable/adapter, that much I do know!
i have the CLK Device (WiFi version) which is the OBDII connector. So now I would just need the software and update, thanks.
I don't think you can update it over the OBDII
Originally Posted by bimmerspeed
(Post 1549493)
is there a way or a tutorial that i can do it instead of taking the car to a shop? It sounds like I need the software "Autologic" to but other than that I would need the update package. Any help would be appreciated B) I would recommend you take it to European Auto Source in Anaheim. https://europeanautosource.com/ If you're VO is different let them know ahead of time that way I believe Jeff the owner uses Autologic a different way to update modules. With Autologic he can update entire car in like an hour. |
Thanks, I'll hit them up tomorrow!!!! :)
