5Series.net - Forums
-   -   iDrive screen signals (https://5series.net/forums/e60-discussion-2/idrive-screen-signals-18986/)
eugeneloke Nov 26, 2005 05:40 AM
I stripped out the CID screen today
noticed that the connectors are non-standard
(as in not RGB nor VGA)
one is obviously for power
the other is prob combined signals or something
has anyone tried converting the signal to RGB?
hoping to use my larger LCD screen which i use now to view DVD to display idrive info as well
Rudy Nov 26, 2005 06:56 AM
The following post will give you links to everything you ever wanted to know about the CID...
http://forums.e60.net/index.php?s=&showtop...ndpost&p=103940
eugeneloke Nov 27, 2005 12:11 AM
do you know what the resolution is?
i men even if i got the interfaces to connect a dvd for example, how good will the picture be?
