iDrive screen and CDs
Interesting but way too expensive, Do yall know how much it would cost to get the OEM iPod integration done? What parts are involved, can I buy parts and install myself and simply have BMW code it into iDrive? Or is it simply plug-n-play?
Just burnt an mp3 CD with itunes and it did not work at all, the car didnt recognize that I had put a CD in. Is it possible that my car is too old to play mp3 cd's? Build date, 03/2004.
My Ride: 2007 530i Alpine White with Navi and Premium PackageIn progress: OEM Mtech kit, H&R Sport Springs, and 19
FYI, Itunes is the worst at burning mp3s for our cars. It sorts them and places them in folders by artist name and causes the tracks to change slow. Dont use Itunes for burning mp3...
My Ride: 2004 530i
This is a separate issue. You car is not coded to play MP3 in the CD player. 2 options: the dealer or indy shop that can do coding.
My Ride: E90 M3
Model Year: 2011
Looking at your signature, I think so! For a 2004 car, you need to have Navigation which uses a different computer system which is capable of MP3 playback. But you needed a software update to get it functioning. If you don't have Nav (and it's not in your Sig) the MP3 playback is not possible.
My Ride: 2008 Jet Black 528i Navigation, heated seats, premium
In my 2008, CD TEXT is supported, which means that any standard audio CD(not MP3 CD, which is a data disc) which was burned with CD text as an option will show text information on the screen. iTunes does allow you to burn a standard audio CD with CD-Text, but you have to check it when burning the CD. I haven't found that too many commercial CDs were made with CD-text. CD-text
MP3 CDs are totally different, as they are not an audio CD, but in fact a data CD with data files written to them. Those data files just happen to be music, which can be played back from a CD drive capable of processing MP3 files. My car will play them back, although I agree with the previous responders, iTunes is not a good choice for creating MP3 CDs. The ID3 tags(which contain the text information) is kinda screwy when burning from iTunes. You also have to take bit rate, variable bit rate, and ID3 tag version into consideration, which iTunes isn't very good at. Plus, anything purchased from the iTunes store is an AAC file, which my car doesn't understand if read from the CD or DVD drive in the car. Although, it does understand them if they are played back from an iPod using the iPod connector kit.
Long and short, to the OP: I would go into iTunes and make sure that "CD-text" is checked when burning the standard audio CDs which your car can read. I just don't know if your year/model supports CD-text or not.
My Ride: BMW
My Ride: E90 M3
Model Year: 2011
I don't have NAV and my car (2006) can play MP3 CDs. There was some mention here that the dealer can update your car for free so that it can play MP3 CDs. I don't recall what conditions have to be met in order for them to perform this. Also, you will need this capability if you want to install the iPod retrofit in the future. Hopefully somebody will see this thread and chime in with that service bulletin.
My Ride: Coming soon...
Not even CD's that I've purchased from the store show up with song titles and artist. So whats the point of the iDrive with RDS and all that if it cant even display song names of a CD?? The RDS and CD info (assuming its capable) must be linked right? ![Think](https://5series.net/forums/images/smilies/imported/think.gif)
I've been thinking about an iPod integration but the stock OEM doesnt allow for both 6-disc and ipod. I've seen both in E60's by means of an aftermarket mod, dont know all the details though...
Song info from a CD comes from files stored on the CD itself. In the case of mp3s, the data comes from what is called an "ID3" tag. It is this tag which must be read by iDrive to display the song info you want. In order for this to happen you need to
A) Ensure that you have a software version capable of reading these tags
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
C) Get the iPod integration kit and all your problems are solved!
My Ride: 2004 530i
