5Series.net - Forums
-   -   idrive nav software update (https://5series.net/forums/e60-discussion-2/idrive-nav-software-update-80525/)
whonneb Jul 1, 2009 02:27 PM
He guys, I picked up an BMW North America Version 2008 dvd off ebay, however when I put the dvd in my system, nothing happens. Do I need to put the system in some sort of mode for this to update?
terry79z Jul 1, 2009 02:36 PM
Screen gave me an alert to turn off system for 5 minutes while reading new DVD.
(I wasn't sure if I had to turn off engine or reset NAV)
I turn off engine and got out of the car (with key)....restart my car in few minutes (I cleaned up trunk area meanwhile)...
and it was reading new DVD automatically.
Hope it helps
whonneb Jul 1, 2009 07:18 PM
Hope it helps
mine doesnt do anything. Do anyone have the instructions on the installation of this software?
r9ndy Jul 1, 2009 07:34 PM
i believe there are different versions for navigation
MRV99 Jul 1, 2009 07:38 PM
There is NO installation of software. You place the disk in the DVD drive and that is all the installation you have to do. If the disk is good or works, it will ask you to turn your car off for 5 min and then it will work. If it does not work, I tend to believe that you did not purchase the correct disk or is not an authentic (maybe a burned disk with a laserjet cd sticker to make it look OEM) Sorry to hear and good luck getting it working.
luigi524td Jul 1, 2009 07:43 PM
Unlike the earlier BMW NAVs there is no 'software' loading into the NAV from the DVD. I wonder if you bought an "original Navteq DVD or a copy ... if the latter it may be faulty. The correct map DVD is the Professional ... and your car will take up to 5 minutes to 'recognize' the new DVD.
If you don't have an owner's manual [very helpful for car features / operation] they are posted on the info section of this forum. http://www.e60.net/information/
irshad Jul 2, 2009 01:58 AM
Do u have a recent idrive software. Here in Holland it's not possible to run the newest Nav DVD if you haven't the most recent software update.
vern Jul 2, 2009 05:52 AM
Sounds like you been had. See if you can get your money back and report it to EBay.
good luck
cheers
vern
toneil44 Jul 24, 2009 10:06 AM
Does the installation of a "good" Nav DVD affect Nav memory? I have almost 100 addresses in that memory. Would sure like to know ahead of time if it is going to be wiped out.
VW2545i Jul 24, 2009 11:03 AM
I loaded a disk from my buddy and now my nav is frozen, so I think I need a trip to the dealer.
