idrive fix for e60
Old Dec 3, 2013 | 02:04 PM
Takecare14's Avatar
My Ride: 545i
Default idrive fix for e60
Recently had my windows and tail lights tinted. upon picking up the vehicle noticed my battery cover seemed to have been messed with. didn't give it much thought until I turned the car on and my idrive was acting erratic. the volume symbol showed it was on mute but the mute button would not work. also when trying to change over to aux the menu would jump back to fm radio. after trying to select an fm station it would then jump up and down between the stations and the top of the menu where it shows the fm am cd aux. after speaking to the shop that did the work with no help I looked online and was able to piece together some posts. i assume that the battery died when they were working on the car and they jump started it improperly. after trying these steps everything returned back to normal. I just wanted to share this incase anybody runs into a similar problem.
-with the car off I inserted the key and turned it to position 2 without starting the car
-I then turned the headlights on using the manual on setting
-after that you must remove the positive battery cable
-go into your glove box and remove fuses 15 and 7(look in trunk for exact location)
-let the car sit for 5 mins
-after sitting hook battery back up and replace fuses.
-start vehicle
that should fix the problem you will just have to reset date and time.
hopefully this helps out somebody. saved me a trip to the dealer and a lot of phone calls.
Old Dec 4, 2013 | 06:54 AM
wcr3d's Avatar
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
Bavarian witchcraft? I'd be more interested in how you concocted this remedy. If it helps someone then it is well worth it.
Old Jul 26, 2015 | 03:14 PM
kvtire's Avatar
My Ride: 2004 bmw 525i
i am having the same issue on my 2004 525i. Do you know if it would be the same fuses to pull? Thanks for any help. This is driving me crazy
Old Jul 26, 2015 | 05:00 PM
seven11's Avatar
My Ride: 535
check if you have water on your electronics in the trunk
happens a lot when tinting windows
Awest91
Sep 17, 2022 11:05 PM
Kasmo
May 7, 2019 03:30 AM
Quojo
Apr 1, 2015 04:00 PM
ZeZe
Oct 15, 2003 12:58 PM
