iDrive corrupted characters and now blank screen
My Ride: 2006 530i Alpine White , Premium Package, Build Date 07/05.
BBBB-BONE STOCK
Hey guys,
I need your help with my 06 530i. This morning when I started the car, the iDrive started doing something funny. It had these weird characters and the language was incomprehensible or missing in many places. I took some pictures of what it said, and it keeps changing every time you move around. I tried shutting off the ignition and retrying but no avail. I drove the car to work, left it there for a good 8 hours, and now when i come back it's completely blank.
I tried searching for the idrive reset procedure, (i.e. hold down the power button and CD eject button), but that didn't work. I don't have navigation by the way so I'm not sure I'm resetting it correctly. This is the first time it has happened. I checked a coupple of fuses (many #34 and #35 which are the radio and the control system, 10amps -- and they are fine). No water leaks in the battery or wheel well area either.
What should I do? I still have CPO, but not sure if it's covered under this.. Probably have to pay the $50 deductible.
I can probably drop the car off this weekend, as I'm going overseas for a week, so it'd be good timing to leave it in service. Let me know, thanks for your help.
It should be covered under CPO. If you get push back, ask the service adviser how you are expected to manipulate the climate control without the iDrive screen working. The answer is "you can't", therefore, it needs to be covered. Same can be said for any of the other functions available only through the iDrive.
+1 on the warranty, should be covered with no issues. You could always try disconnecting the battery overnight if you dont want to mess with the dealer.
GL
BBBB-BONE STOCK
Hi all,
update. It seems you three are saying it's covered by CPO, my service advisor said it wasn't. Here's the section quoted from the CPO website, and the CPO warranty dept. declined:
Not Covered: Radio/cassette player, telephone, navigation system, CD changer, or any components of those systems; non-original equipment parts, components or accessories
Since I-drive is a component of the radio, telephone, cd, etc. it's not covered. It controls those systems, therefore, it is a component of those systems.
I'm not happy as the advisor tried to get me on some other recommended fluid services I did not come for (which were declined in the past) so that he could just 'do me a favor' and include the replacement cost of the i-drive in there free since it's not covered. The service would end up costing me 1/3 of the i-drive, vs. the 2k i-drive by itself. On the surface, it sounds like a good deal, but these are maintenance items which I may or may not need. I shouldn't feel like there's strings attached to getting my car repaired for something I initially came in for (even if it is "cheaper" for the option recommended) -- I was expecting $50 for the deductible and that was it.
Any advice? I am going to write to BMWNA.
My Ride: BMW
Wow! That's some total BS. I would be pissed. Like the other poster says, how are you going to check on other parts of the car like checking on fluid levels and brake maintenance? While it's true, it is part of the entertainment system, it's also part of the health and monitoring of the car itself.
Then try this, tell them to at least fix the part so that you can navigate the service menu and climate controls.
Balbs
Balbs
BBBB-BONE STOCK
Balbs
Balbs
einstellungen is "preferences" or "settings" so it looks like something in the iDrive reset to German.
It might be that the current flash image of the iDrive is corrupt. This could be resettable by removing power from the battery to the car. simply pull the NEGative battery terminal off. Wait an 30 min to an hour. Reconnect.
If that doesn't work. See if the SA would be willing to perform a CIP update. This is just a firmware (software) issue.
checking oil level !!!!! - you can't do that task without the screen, isn't the enough??
various heating and a/c things
heated seat control if you have comfort seats
all the various CBS (condition based service) indicators (brakes, etc.)
changing the door locking and unlocking things
changing the triple turn signal setting
changing the entry/exit lighting setting
etc
etc
etc
Bring the list to the guy and tell him these don't work. Ask him to fix these without fixing the parts that aren't covered.
