iDrive, Buttons, & Settings: Ur Techniques?
Old 10-05-2005, 06:27 AM
znod's Avatar
Yep! Btw does the car allow you to pass those restricted revs? Never tried it and for sure never will.
[snapback]179762[/snapback]
You can't exceed redline. In the auto, the tranny will shift for you. My supposition is that the manuals and SMGs have rev limiters.
Old 10-05-2005, 07:22 AM
ChennaiMR's Avatar
Originally Posted by donv' date='Oct 5 2005, 10:22 AM
[quote name='JC3168' date='Oct 5 2005, 04:16 AM']Hi donv,
Thanks for the tip on how to get rid of the "Accept" screen. Will try it when I get back into my car.
You know where it the "temp guage" for the 5 series? It's built into the tech meter.
Cheers!
[snapback]179692[/snapback]
Thanks. I'll check it out. Not sure exactly what you mean though.
[snapback]179766[/snapback]
[/quote]
There are small markings in the tachometer that appear/disappear before the redline. This is an implicit temperature guage...and if you observe it early in the morning on a very cold day, you will see more of them between 5000 and 6500 rpm. As the engine warms up, these markings slowly disappear starting from 5000 until you see no more of those upto the redline.
I wanted to post a picture illustrating the above...but dont know how
Old 10-05-2005, 07:25 AM
ChennaiMR's Avatar
I use this voice command very often
'Map Direction of Travel'
This seems to be the fastest way to get to the destination
Old 10-05-2005, 08:08 AM
Bimmer32's Avatar
This seems to be the fastest way to get to the destination?
[snapback]179794[/snapback]
1. Turn ON the car.
2. Press the Accept button
3. "Turn off" the diplay from steering wheel.
3. Listen to the Radio
4. Wife fiddles with the "knob" . . . OK to change the radio stations. In a 30 minutes ride, she changes the station on an average of 50+ times. Yes, I made a mental count. Lord knows, if I activate Sirius, the knob will break in a year.
5. Change volume, mute, and station on Steering wheel.
There's my routine. No Nav. I used that money for a new laptop and a GPS module. Works Great.
Old 10-05-2005, 08:37 AM
rodneyremington's Avatar
My Ride: 2005 545i with everything
Originally Posted by Bimmer32' date='Oct 5 2005, 09:08 AM
[quote name='ChennaiMR' date='Oct 5 2005, 10:25 AM']
[snapback]179815[/snapback]
I'm sure it works but do you really find having a laptop with an external GPS module (presumably) sitting in your car more convenient than an integrated nav? Sure, it's cheaper but doesn't sound that user-friendly. I suppose by that same logic it would be cheaper to not get a sound system in your E60 and get a ghetto-blaster set up in the back seat.
Old 10-05-2005, 09:38 AM
znod's Avatar
Originally Posted by ChennaiMR' date='Oct 5 2005, 10:22 AM
[quote name='donv' date='Oct 5 2005, 10:22 AM'][quote name='JC3168' date='Oct 5 2005, 04:16 AM']Hi donv,
Cheers!
[/quote]
[snapback]179792[/snapback]
[/quote]
I see. That is what he meant. Yes, I have observed those too. And, for an earlier question, I am not sure if you can exceed these "tentative" redline numbers.
Old 10-05-2005, 10:10 AM
Bimmer32's Avatar
Originally Posted by rodneyremington' date='Oct 5 2005, 11:37 AM
[quote name='Bimmer32' date='Oct 5 2005, 09:08 AM']
[snapback]179834[/snapback]
[/quote]
Well, the logic behind the no nav. is that for the past 15 years, I seldom used a map (even when I had a travelling job) in the car. For the same price, I can watch movies, GPS, etc (and everything else you can do with a computer). My decision was based on utility. You can say I'm good with directions. I can look at a map, write down the address, and I'm there. Now, if I paid $1200-$1800 for a handheld nav., then yes, your logic would hold truth. User-friendly . . . relative.
With regards to sound, I have premium sound (h/k) and not the standard despite 80% of my listening is talk radio (news). I would never put in an aftermarket sound unless it's Mark Levinson. I'm the type of audiophile that likes the direct sounds instead of the "Bose" type sound, so HK is good. I have Yamaha receiver and polk audio at home.
Old 10-05-2005, 02:04 PM
znod's Avatar
I forgot a useful technique earlier. It turns out that the joystick often can be used as/thought of, in effect, as a back button--because among other things moving and holding the joystick lets you toggle among the main functions of the iDrive. One of my desires is a dedicated back button, or the equivalent, for the iDrive.
Old 11-06-2005, 08:17 AM
amigo525's Avatar
Is the accept warning goes away on the 06 after few seconds?
Just got my car and after 4-5 secs, the accept warning goes away automatically.
I prefer that way much better.
Old 11-22-2005, 12:36 PM
katheikia's Avatar
My Ride: 2006 550 SMG
Originally Posted by marty530d' post='179699' date='Oct 5 2005, 04:56 AM
One tip that I would love to hear is :
How to cancel a TP Traffic Announcement once it has started - the only way I have found it to turn audio on/off and then it returns to your current radio/CD/MP3.
What is TP traffic announcement, I dont get it, is it a feature in all e60s?
Quick Reply: iDrive, Buttons, & Settings: Ur Techniques?
