Idle Problem (again)
After dealing with the stealers for couple of days I decided that forums know better anyway
! Couple of weeks ago I bought an '04 545i 40000 mls, and hence the title it has an idle problem, not just when its cold, always! As the car is parked or at the light the rpm's slightly go up and down continuously, and sometimes a little more, even that you can feel a slight shiver...
Dealer reprogrammed the car and "re-learned" its valvetronics(I believe) WHY? and charged me since CPO does not cover this??!! However it didn't do anything ! Now they want to clean its injectors etc. and told me that that also isn't covered by the warranty and it is regular maintenance!!
At this point I just did not want to deal with them anymore and their speculations so I took my car! What do you guys think I should do, and what is the problem? SHould I clean injectors or the top end as they called it?? How can I do it myself? What else could be the problem? Thanks!
Originally Posted by pgetsch' post='779306' date='Jan 28 2009, 11:15 AM
im having the same problem, no pattern to the vibration, just a hum or shiver when the rpms go to about 500 right? i cleaned injectors with some gas additive from bmw, no help. i brought the car in a week ago they changed the cam sensors, no help. i have a diagnostic tool that told me it was an idle motor so when i go back to the stealer im suggest checking the idle. no performace issue and it goes away once i tap the pedal but it annoying at red lights and when the car is in park. ill let you know how it goes
Originally Posted by ktlocklear' post='779332' date='Jan 28 2009, 12:20 PM
Have you cleaned the MAF yet? Start with the easy stuff ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
My Ride: 2004 BMW 530I SPORT. BLACK BEAUTY. HEADS UP, NAVI,AC SCHNITZER ROOF SPOILER, TRUNK LIP SPOILER, 20 IN AXIS PENTA (NOW PAINTED BLACK). M-TECH KIT, EIBACH SPORTS.
Originally Posted by Phantom Mark' post='779365' date='Jan 28 2009, 12:05 PM
If it was any other older beema I would say idle control valve, did one on my old E34 525i sport...........
My Ride: '06 550i
'84 Nissan S12 Turbo
Originally Posted by europower' post='779340' date='Jan 28 2009, 10:29 AM
I was going to, but what tool do I need to take it off?? On my e46 M3 it was a 6 star torx on this one its five... Where can I buy that??
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Agree with the spark plugs - how many miles do you have on your car??? I had this exact same problem - changing the sparks out [not covered by CPO] completely solved the problem! Good luck to you...there was never a diagnostic test at BMW that confirmed this so it's a bit of a crapshoot BUT...this would be a good place to start if your nearing or over 50K miles in any case...
