Identify xenons
Old Aug 17, 2005 | 07:47 AM
Musezic's Avatar
My Ride: 535D Saphirschwarz, Truffelbraun interior with antthrazit roof - Heated comfort seats, Sunshades, Lateral airbags, Pro Navigation, Head-Up display, PDC, Sports steering wheel, 138 rims with run flats, Built in SE P800
Hi to you all
Just picked up my 535d she's gorgeous that's for sure!
But the salesman mentioned that I had Xenon's but I'm sure I did not order them...
He mentioned:
- The halo's
- cut out for the head light washers
- the fact that there ain't no wheel to adjust the beam height (when heavy loaded...)
Do I or do I not have the xenon lights ??
Ofcourse i wouldn't mind if i got them
Old Aug 17, 2005 | 08:08 AM
paasan's Avatar
Take a look at them? They should have a blueish hue.
Old Aug 17, 2005 | 08:29 AM
fred1976's Avatar
My Ride: 535d
Thumbs up
Originally Posted by Musezic' date='Aug 17 2005, 04:47 PM
Hi to you all
He mentioned:
- The halo's
[snapback]160252[/snapback]
I think the saleman is right. I've the same car model with the same option and ordered in BENELUX also. The washing system is only mandatory in our countries for the Xenon which are using all their efficiency as soon as there is dust in front of the lens. You clearly see you have this with te cutted squares that are in front of the front headlights. The adjusment wheel is actually not present because at any time a system adjusts the vertical direction of your headlight (also horizontaly if you ordered the optional curve adjustment module) so you do not injure the people coming from the oposite direction (due to the lens and the extra white beam, having that in the face is an horror; maybe you have experienced this with the not quick enough renault Xenon system coming from the opposite direction). Finally, a very simple way is to look at your headlights, the biggest ring, If there is a diverging lens (like a camera lens) in the middle, it is xenon; if you have a simple metalic parabolic converging surface like the light in the middle of the small ring, it is classical halogen bulb. Other indication : open the engine compartment and look at the headlights from above. You should see indications such as (be carreful, high voltage or so to warn you that you should not replace them alone without knowing what you are doing not to have an electric schock (very high intensity)).
Finally, Ask your dealer to compare with a 5 with classical halogen lights in the showroom / you ll see imediately the difference.
When my car was delivered, I got the same type of question for the HiFi system. Experience show taht there is always a -simple- way to figure out if you have an option or not.
This question appeal another : have you also the pre-ventilation with chronometer in your AC menu???
CU
Old Aug 17, 2005 | 08:40 AM
ledbettm's Avatar
My Ride: On order: 2007 550i, silver gray, black leather, anth. maple trim, active cruise, heated steering wheel, sport, night vision, vent seats, heat rears, active steering, rear air bags, folding seats, comfort access, navigation , HUD, black head liner, steptronic, premium sound, sirius and HD radio.
Open the hood. If there is a warning label about high voltage on or very near the headlights then you have Xenon
Old Aug 17, 2005 | 11:22 AM
UUronL's Avatar
My Ride: 2006 530i Sport Silver Gray - Black Leather - Anthracite Maple Manual Transmission Premium Audio Cold Weather Package Rear sunshade Sirius Radio Autobahnd Roadblock (3M) film kit
Xenon vs. non. Look at the centers of the lights.
Old Aug 17, 2005 | 11:25 AM
tomwid's Avatar
My Ride: Jet Black 545i
Huh, yea it's pretty apparent. The xenons have a projector mounted inside the housing. Regular halogens don't have the projector, you can see the bulb clearly in the halogen housing.
Originally Posted by UUronL' date='Aug 17 2005, 03:22 PM
Xenon vs. non.? Look at the centers of the lights.
[snapback]160360[/snapback]
Old Aug 17, 2005 | 12:12 PM
Merv the Derv's Avatar
My Ride: 535D Sport Auto
If theres no adjustment wheel in the car then you have them
Vman33
Mar 14, 2022 04:43 AM
Kaane
Sep 26, 2015 07:44 PM
umnitza
Sep 2, 2015 11:28 AM
knklhead
Aug 20, 2015 08:40 PM
boozooface
Jul 28, 2015 09:17 AM
