Ice warning
Old 11-25-2005, 10:42 AM
Ricracing's Avatar
Dear mario.kwok,
Are you into 230 V or something?
If you are, check the www.defa.com site.
Even if my car is under 30cm of snow, the car is warm inside!
After that I just push the snow off my car, start it up, put on the seating heater,
turn off the DSC and drive off.
Trust me or not, I'm not bullshitting, you are welcome to see what the winter is all about!
Cheers,
Riku
Old 11-25-2005, 12:20 PM
mr_djurgarden's Avatar
Mine works fine
Old 11-25-2005, 12:31 PM
gdavis's Avatar
mine always gongs at 3C or 37F. It takes over the HUD and the top of speedo cluster and at bottom of idrive.
Old 11-26-2005, 11:02 AM
wowe's Avatar
My Ride: BMW 530i 05 M-technic Silvergrey whith beige dakotaleather
Yesterday it show?d up once but after that nomore. I will go to my dealer for a cip uppdate when the new version comes. Does enebody know when it comes?
Old 11-26-2005, 11:09 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
It comes on when the temperature hits 37 degrees Fahrenheit (about 3 degrees C) but does not stay on during the drive.
Once it warns you, it won't warn you again unless the car is turned off and back on again or the temp rises above 37 and falls again...
Old 11-27-2005, 01:02 PM
wowe's Avatar
Today we had tempratur under 0 and it did not show up onec when I startdet my car
Old 11-27-2005, 01:22 PM
paasan's Avatar
wowe: Probably because the temperature was below +3'C when you shut off the car the last time. The warning sounds whenever there is a CHANGE from +4'C or more, and down below +3'C.
Old 11-27-2005, 01:37 PM
wowe's Avatar
Okej now I anderstand what you mean. Thx :)
Old 11-27-2005, 01:47 PM
BMW530's Avatar
Originally Posted by mario.kwok' post='203253' date='Nov 25 2005, 05:46 PM
I know it is getting a bit annoying seeing that everyday now. What's more annoying is that I have to get the frost off the windscreen every morning. (you know what it's like when you're rushing to work every morning. <_< Even a normal cheap 15 year old Ford is equiped with heated windscreen........
As I know some model is equiped with Auxilary heater which allows you to set the timer to heat the car up. Well, I'm told by the dealer ths option is not available on petrol models. < It is true???
Heated front windscreens (thin tiny elements on windscreen) are apparently a patent by Ford. This is the reason why they only occur on Ford cars. Obviously they can occur on Ford owned companies like Jaguar. Its a very useful feature as I had it on my Mondeo a few years ago.
Old 11-27-2005, 04:40 PM
Mr 5er's Avatar
My Ride: 2005 525i Titanium Silver Metalic and 2003 325xi Jet Black with the Premium Package in both cars.
Yep....mine pops on at 37 degrees, gives me that yellow snow flake and disappears. It annoying at best, but what da hell.
Quick Reply: Ice warning
