I will never use mobile 1 again in my life
My Ride: Mini Cooper
I put mobil 1 this time cos my frend had 3L left over from his car so I went and buy other 4L to put in the car.
I change the engine oil on Sunday and it was 5-50 mobile 1.
wow the car is not as quick as before
I had lubrolene, last time
So from no on I will never use mobil 1, for about the same price as mobile 1 there are much better engine oils out there.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: 2005 530i, 1995 318ic
retired circa 1970 2002, , circa 1985 320, 1998 528i, 1998 740i
Originally Posted by pinguhk' post='434568' date='Jun 11 2007, 10:58 AM
I put mobile 1 this time cos my frend had 3L left over from his car so I went and buy other 4L to put in the car.
I change the engine oil on Sunday and it was 2-50 mobile 1.
So from no on I will never use mobile 1, for about the same price as mobile 1 there are much better engine oils out there.
My Ride: 2015 535D M Sport
If by "2-50" you mean 20W-50, then that oil is too thick for your car, although I doubt you'd notice a performance degradation. BMW specifies 0W-30 or 0W-40 as I recall. Your gas mileage will suffer a bit with anything thicker. RTFM.
My Ride: 2004 530i Xenon, Sport, Premium, Automatic, Logic 7, Orient Blue & Auburn Dakota Leather with Dark Poplar Wood Trim
You must use 0w-40 or 5w-30 Mobil 1 only !
Here in hot south florida the dealer is using 5w-30
My Ride: 2005 BMW 545i / Black Sapphire Metallic / 6spd. manual / Sports package
I highly doubt that you will a feel a difference in performance between using two different engine oils...Mobil 1 is awesome for a mass marketed engine oil and it's also relatively inexpensive compared to other oils with the same characteristics....Smaller 'brewers', such as Amsoil,RP,etc. provide the same, but usually with longer intervals between changes.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
I don't see it as a problem of the oil itself, but someone putting the wrong stuff in.
My Ride: 2007 530i | Silver Gray/Blk | Step-Tronic | Sport/Premium Package | Logic 7 | PDC | Fold-Down Rear Seats
I remember you suppose to use 5W-30 full synthetic. BTW, although castrol is the official oil for BMW, I know a few dealers in the bay area who actually uses mobil 1. MB's also use mobil 1. So I wouldn't think it's that bad of a brand if both german goliaths replenishes with it.
Originally Posted by fjwagner' post='434590' date='Jun 12 2007, 12:54 AM
Not sure what you mean by 2-50 Mobil 1 (no "e"on the end). I really doubt you could tell a performance difference in Mobil 1 versus any other equivalent weight motor oil unless you put the car through some controlled dyno tests. I have used Mobil 1 for years and never noted any problems. I changed from conventional oil in my 1995 3 series to synthetic Mobil 1 years ago and found less valve clatter on start-up and possibly improved mileage. However, I expect that I would have noted those items with any synthetic. Check out www.bobistheoilguy.com to read more about engine oils. Oils are required to meet certain specifications so you are going to get good performance out of any that meet the required specs. Different brands have different additives, but any of the name brand oils are good.
well before I had 5-40 and now 5-50 and the engine is not a smooth. I can feel the oil is much thinker than before.
I think I will stick to that next time.
Originally Posted by pinguhk' post='434833' date='Jun 11 2007, 10:02 PM
thanks for tell me that I spelled it wrong, I am dyslexia so cant speel to save my life. and the 2 is ment to be a 5.
http://www.mobiloil.com/USA-English/MotorO...erformance.aspx
