I think my fan has failed...
Old 08-31-2016, 04:14 PM
  #21
MCR
MCR's Avatar
My Ride: 545i Sport Oxford Green
Yup... My rear locking slide thingy was unlocked and all the rear half of the cover screws were....... All the way loosened.
Someone needs to make a harness kit to relocate the dme inside the vehicle.
Old 08-31-2016, 05:37 PM
  #22
KyleB's Avatar
My Ride: 530i
Engine: M54
The DME in my E30 is in the glovebox...from the factory. I have no idea why they started moving it to such prone area.
Old 08-31-2016, 06:00 PM
  #23
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
KyleB, I'm confused why you think the problem is "final stage unit of the fan". Think about your experiment. You told INPA to run the fan at various speeds and it worked fine. That means the final stages of electronics in the fan can do their job.
Old 08-31-2016, 06:09 PM
  #24
MCR
MCR's Avatar
Did you pull the plug on the bottom hose sensor to verify full fan speed default?
In my mind... If the speed increases when you pull the plug, it could be the sensor at fault.
Old 09-01-2016, 04:49 AM
  #25
DanielFD's Avatar
My Ride: 2007 BMW 550i
Something still tells me a reset default code on the IHKA and ECM might solve this as INPA is able to change fan speed correctly.
I'm no pro, but worth a shot.
Old 09-01-2016, 09:37 AM
  #26
KyleB's Avatar
My Ride: 530i
Engine: M54
no faults in DME or IHKA. however, fan failures dont always trigger faults in DME.
Old 09-01-2016, 09:38 AM
  #27
KyleB's Avatar
My Ride: 530i
Engine: M54
checked...sensor unplugged, 0, zilch, nada fan movement with engine running. sensor is new.
Old 09-01-2016, 11:31 AM
  #28
MCR
MCR's Avatar
Strange.
Check the grounds?
Old 09-01-2016, 11:35 AM
  #29
KyleB's Avatar
My Ride: 530i
Engine: M54
Strange.
Check the grounds?
grounds are good. if they weren't i wouldnt be able to get the fan to spin anywhere close to 90% using INPA.
Old 09-02-2016, 04:33 AM
  #30
DanielFD's Avatar
I'm not talking about faults on the ECM and IHKA. I mean i love playing around with coding in our cars i'm sure you do too. maybe there is some setting that you changed that is causing your fan issue. Thats why i'm saying try reset coding it. I'm sure i've seen fan value settings while coding.
Quick Reply: I think my fan has failed...
