I have an odd issue with the factory radio
My Ride: 650 Grand Coupe
Model Year: 2016
I don't have the L7. When listening to the radio at louder levels, the base (subwoofer) will cut out every once in a while for about a couple of seconds and then kick back in. It doesn't matter whether I'm listening to Sirius, the IPod, or FM, the result is the same. At average volume levels, this does not occur. Have any of you experienced this?
Could have something to do with overloading the system,
and your ears for sure.
My (EU) Hi-Fi speaker system (10 loadspeakers, not the L7) can do as much
as the speakers hold without interference and that's very loud to me.
Same thing was happening to my subs. I think it was due to overheating on the factory amp as it only happened after listening to moderate level of music for at least 20 mins. When I installed my aftermarket subs/amp I turned the sub output level on the radio all the way down as it was plenty loud and I haven't had the problem since.
I think if you're getting drop-offs on all inputs (Sat/IPOD, etc) it may be a radio problem. Is is just the bass dropping off ?? SAT radio in some areas where you live has a few dead spots.
Model Year: 2016
Originally Posted by luigi524td' post='731223' date='Nov 25 2008, 04:34 PM
I also have L7 and it handles lows and mid-range quite well ... as you know my son is in music, still has a good ear, and he says
to the audio in mine.
It is just the bass, but it doesn't matter whether it's the Sat, Ipod, AM/FM or CD. Sometimes I'll hear a little pop, then the bass drops for a few seconds and then returns. And, when I said louder volumes, I don't mean really cranking it up to ear bleeding levels, just a little above moderate.
I don't have the L7 though unfortunately.
Model Year: 2016
No, unfortunately the issue is still there. As I expected, the dealer couldn't duplicate the issue, but I can always get it to cut out if I want to. I think they just didn't want to deal with it. My guess is what Ricracing said above. It's probably some overload protection system.
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
Yes, it could be the amp overheating and going into thermal protection. Your amp is easy to access if you want to use your hand to check temperature.
![Brr](https://5series.net/forums/images/smilies/imported/brr.gif)
My Ride: G30 M550i
Model Year: 2018
+1 to the overload (or thermal) protection theory...it makes the most sense from a logical standpoint.
The L7 amp has a bunch of fans that, after a period of loud listening, can be heard spinning even after the car is turned off!
![Cool](https://5series.net/forums/images/smilies/cool.gif)
