I Drive Menu /Coding screw up
My Ride: 535I twin turbo basic for most part.. FAST
Coding today and somehow jacked up my I drive menu. I hit the menus button and it seems to be an M sport menus. Was trying to code kombi for sport mode is there a way to reset to factory and will start over.
thanks for the help
thanks for the help
Thanks for the quick reply. This forum kicks ass people actually are willing to help instead of talk s*** all day long thinking they know everything and tell you to go search through 500 freaking pages of crap just to get to the meat on the bone. I am a new owner and have coded everything there is to code on my E60. Thought it was worth giving this sport module a try. Because I have CCC there are limitations unfortunately. I want to go cic but it's too much for the conversion.
My Ride: 530i
Engine: M54
sounds like you have it reverted back to stock then. yes, coding can be dicey at times, but it sounds like youve done quite a bit of it. i have CIC in my E90, it is a huge upgrade but in all honesty, i also dont think its worth the hassle. id just revert back to stock and leave it. unless you have a 535i, 550i, or an M5, the E60 is nothing more than a nice, comfortable, "fast enough" cruiser of a car.
Engine: N54
These days, the thing to do is to reflash the transmission.
Check out xhp flashtool
