I hope that can help.
Any observations are wellcome. iDrive | |- Communication | | - Phone | | | | |- 0-9 Please enter unlock code | | | | ' - Confirm unlock code | | | '-Call | | | |-Accept | | | '-Reject | | |- Dial | | | |- 0-9*#+ | | | '- Dial number | | |-A-Z (phonebook) | | | '-A.. D.. J.. O.. RST.. W.. Z | | | '-Edit | | |- Top 8 | | |- Redial | | |- Received Calls | | |- Missed Calls | | | |-Call | | | |-Delete | | | '-Delete all numbers | | ' - Active Calls | | | '-Keypad | | | '-0-9#* touch tone | | |-End call | | '-Keypad | | | |- SMS | | | (list of messages) | | '-Options | | |-Call sender | | ?-Delete | '- BMW Assist | |-BMW Info | | ?-Update status reports | '-Where to go? | ?-New data request | |- Navigation | |- Navigation | | |1- New Destination | | | |-List | | | | |-Start guidance | | | | | '-Continue guidance to dest.? | | | | |-Information on destination | | | | |-Edit | | | | |-Delete entry | | | | '-Add to address book | | | |-Enter address | | | | |-Country | | | | |-Zip code | | | | |-City | | | | |-Street | | | | |-House number | | | | ' -Intersection | | | |-Information | | | | |-On destination | | | | |-On location | | | | '-On a new destination | | | '-Input map | | | |-Store current position | | | |-Show current position | | | |-Show destination position | | | ' - Proceed | | | | | |2- Route List | | | - Route Preference | | | |-Fastest route | | | |-Shortest route | | | |-With freeways | | | |-Avoid freeways/tolls | | | |-Dynamic route | | | |-Avoid tollroads | | | '-Avoid ferries | | | - New Route | | |3- Map, Facing North | | | - Map, Direction of Travel | | | - Map, Arrow Display | | ' - Current Position | |- Car Data / On-board info | | |- Onboard Info / Computer | | | |-Arrival time | | | |-Cruising range / Range | | | |-Distance to destin. | | | |-Speed | | | '-Fuel cons. / Consumpt./100km | | |- Trip Computer / Journey computer | | | |-Departure Set | | | |-Travel time / Journey time | | | |-Distance traveled / Distance covered | | | |-Speed | | | '-Fuel cons. / Consumpt./100km | | |- Limit | | | |-mph | | | |-on | | | '-Select current speed | | '- Stop Watch | | |-Start | | |-Stop | | |-Interim time | | '-Reset | '- Address Book | '-Entry (100) | |-Start guidance | |-Edit address | '-Delete address | |- Entertainment | |- FM | | |-Autostore | | | |- Autostore/Store/Tone/Scan | | | '-1-6 | | |-Presets/Memorised stations | | | |-1-12 | | | '- Set | | | |-TP on/off | | | |-RDS on/off | | | |-Save | | | |-Tone | | | ?-Scan | | '-Manual: 88-108 | | 'Set | | | | | |- AM | | |- Autostore | | | |- Autostore/Store/Tone/Scan | | | '-1-6 | | |- Presets | | | |-1-12 | | | '-Set | | '- Manual | | '-Set | |- WB | | |-1-12 | | '- Set | |- SAT | | | ?-Number List | | | '-Call Sirius | | |-All channels | | |-Categories | | | |- Pop | | | |- Rock | | | |- Country | | | |- Hip-Hop | | | |- R&B | | | |- Dnc/Elec | | | |- Jazzstnd | | | |- Classical | | | |- World | | | |- News | | | |- Sports | | | '- Talk/Ent | | | '-Channel A B C D E | | | |-Play>Artist,Track,Album | | | |-Store>Presets | | | '-Tone | | '- Presets | |- CD | | |- DVD/DVD drive | | |- CD:1-8 | | |- CD1 | | |- CD2 | | |- CD3 | | |- CD4 | | |- CD5 | | '- CD6 | | '-Set | | |-Repeat | | |-Scan | | '- Random | '- AUX | | |- Climate | |- Vent Settings | | |- Driver | | | |-Auto | | | ?- +/- windshield/upper body/footwell/cool upper body | | '- Passenger | | |-Auto | | '- +/- upper body/footwell | |- Seat Heater Distribution | | |- Driver | | '- Passenger | '- Independent ventilation | |- Automatic Ventilation | | '-Independent ventilation on/off | '- Activation Time | |-Time 1 | | |-set | | '-activated | '-Time 2 | |-set | '-activated '- iMenu |- Display Off |- Entertainment Settings | '- Audio | |- Treble/Bass | | |-Treble min/max | | '- Bass min/max | |- Balance/Fader | | |-Balance left/right | | '- Fader Front/rear | |- Speed Volume | | '- Speed-dependent volume min/max | |- Equalizer | | '-100/200/500/1k/2k/5k/10k | |- Logic7 | | |- Off | | |- Concert Hall | | '- Theater | '- Reset |- Display Settings | |-HUD selection | | |-Speed | | |-Cruise control | | |-Navigation | | '- Check Control messages | |- Time | | |- Set Time | | |- Time Format 24/12 hour format | | '- Hour Memo | |- Date | | |- Set date | | '- Date format MM/DD / DD/MM | |- Brightness | | |-Head-up Display Offset min/max | | '-Display Offset min/max | |- Languages | | |- Text Language English US/Deutsh | | '- Navigation Voice Instructions on /off | '- Units | |- Consumption mpg / l/100km | |- Distance mls / km | |- Pressure psi / bar | '- Temperature F/C |- Vehicle Settings | |- Steering Wheel Buttons star/diamond | | |-Navigation | | |-Air recirculation on/off | | |-Mute on/off | | |-Screen/Monitor on/off | | |-Next entertainment source | | |-Head-up Display | | '-Horn | |- FTM | | |-Set tire pressure | | '-Status | |- PDC | | '-Monitor display on/off | |- Lighting | | |- Pathway Lighting=60 s | | '- Triple turn signal activation on/off | |- Door Locks | | |- Central Locking | | | |-Lock button | | | | |-All doors | | | | '-Driver?s door only | | | |-Last seat position | | | | |-After unlocking | | | | '-After door is open | | | |-Relock door if not open | | | '-Lock after driving off | | '- Confirmation | | |-Flash when locking | | |-Flash when unlocking | | |-Acoustic confirm. when locking | | '-Acoustic confirm. when unlocking | |- Climate Control | | '-Automatic programs | | |-intense | | |-Medium | | '-soft | '- Delete Data | '- Delete Address Book | '-Yes |- Service | |- Service Requirements | | |-Service notification | | '- Status | | |-Engine oil | | |-Microfilter | | |-Rear brake pads | | |-Front brake pads | | |-Brake fluid | | |-Spark plugs | | |-Coolant | | |-Vehicle Check | | |-State inspection | | '-Emission inspect. | | '-Set service date | |- Check Control Messages | '- BMW Service | |- Roadside Assistance | | '-Start service | |- Service Request | | '-Start service | '- Customer Relations '- Communications Interface '- BMW Service Settings |- Service Status | |-Enable service | |-Update services | '- Terminate services | |-Service Request | |-Roadside Assistance | |-Traffic Info | '- BMW Info '- Profile |-Roaming '-Vehicle color, License Plate, VIN *Service Mode Depress the I-Drive for 6 seconds. Rotate 3 clicks right, 3 clicks left, 1 Right, 1 Left,1 Right, Depress the I-Drive. -TV (for Ergo) -Radio (for SVS) -Versionskontrolle/Controlversions -GPS - Navigation - Tuner? To exit hit the menu button Reboot iDrive:Simultaneously press Volume On/Off Switch, CD Eject, DVD Eject |
1 Attachment(s)
Welcome aboard, CATA Attachment 2645!
:wow: Nice effort! I think Idrive is a lot less confusing in person.
Originally Posted by ULtraPLanet' date='Oct 13 2004, 05:23 PM
:wow:? Nice effort!? I think Idrive is a lot less confusing in person.
[snapback]44474[/snapback] |
Excellent post.
Welcome. |
welcome aboard, cata :thumbsup:! did you hurt your fingers after typing all these :lol:?
I noticed something after my last s/w update to version 13.1 in radio/entertainment menus, I now have a new "option" under "Set" when listening to a station. If you click "Set" I have the usual "TP,RDS,Save,Tone,Scan" but I now seem to have another option called "Favourites" not sure if that was there before????, added it in below, anyone know what it does?
I haven't looked in the manual yet so this could be RTFM :) |- Entertainment | |- FM | | |-Autostore | | | |- Autostore/Store/Tone/Scan | | | '-1-6 | | |-Presets/Memorised stations | | | |-1-12 | | | '- Set | | | |-TP on/off | | | |-RDS on/off | | | |-Save | | | |-Tone | | | |-Scan | | | |-Favourites | | '-Manual: 88-108 | | 'Set |
Why would these I-Drive options be disabled, assuming your Roadside Assist subscription was current?
| |-Service Request | |-Roadside Assistance | |-Traffic Info I also have a flashing red triangle next to the phone signal strength indicator. |
R U kidding me!!! I think I have a headache :D
Nice post..... :thumbsup: |
Nice post..... :thumbsup: This kinda reminds me of those faq's on the net you look up for video games. You know the ones that start with some ASCII art at the top and there's like some official document format that everyone must follow for the whole faq? :D |
| All times are GMT -8. The time now is 03:59 AM. |
