I do not know where bank 2 too lean o2 sensor stuck lean
My Ride: E 60 5 series BMW
Engine: N52
I HAVE READ THE CODE and tell to do
post catalyst fuel trim too lean bank 2
what is bank 2 to fix it
o2 sensor signal stuck lean bank 2 sensor 2
where is the bank sensor 2 ,
Engine: N52
P2098 twice
p2272
p0597
please some help what to do is shaking 6600rpm idle and when brake is on red light or reverse also
is annoying help please
p2272
p0597
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Bank 1 sensor 2 is under the car closest to the engine
Bank 2 sensor 2 is under the car furthest back from the engine
They should be right next to each other oh may want to check the MAF also.
Only use Bosch brand
Looking at the pic the green arrow is bank 1 sensor 2 the yellow is bank 2 sensor 2
Engine: N52
MAF i cleaned already with a good quality MAF cleaner,
You told me bosh how do i order what part it is?
Is the o2 sensor, or how is call the part
Model Year: 05 530i
Engine: 3.0 M54
The pic shows the part number. You can go to rock auto.com, pelican parts, or local auto shop. The part number will still be the same.
Bmw4u (08-09-2020)
