I discovered an oil leak!!
Old 02-26-2013, 06:09 AM
MitchBMW's Avatar
My Ride: 05 545 BLK/BLK
Model Year: 2005
Originally Posted by DavidF
Sadly, with BMW's oil leaks are not if, but when. Usually the culprits are rubber seals, gaskets, and plastic covers (ie. valve covers). I sure wish BMW would improve their seal technology (eg. viton)
I totally agree.. they should be past this by now. I know they are making people very unhappy. And we shouldn't have to just settle..because it's BMW. I know other cars leak oil, but other cars are not BMW. This problem has existed in all of their V8s. and that's a shame.
Old 02-26-2013, 06:50 AM
healthservices's Avatar
Old 02-26-2013, 06:51 AM
Old 02-26-2013, 06:52 AM
Old 02-26-2013, 04:45 PM
Shlooky's Avatar
My Ride: 545i
LOL, so here's a quick update... The oil that was on the garage floor was very clear. I checked the oil level in my car and it was murky/black. So this can't be engine oil otherwise the oil on the floor would have been black.
I'm taking it in on Thursday to my local BMW shop...(Bimmersport), we'll see what the story really is. and if it is a $2000.00 job so be it.
Old 02-27-2013, 03:43 PM
AchtungE60's Avatar
My Ride: E60 530i
You have a BMW, expect it to leak. If it was clear it is most likely hydraulic fluid CHF 11S. Expect that if you have AS (Active Steering) the hose will leak. Shouldn't leak that much though. Can easily be fixed but it may not be worth it. I had to add about 100oz of fluid 2 years ago. I'm not concerned about it.
Then again, if you had the transmission changed with a specific fluid it could be that as well. Pentosin is a clearish/yellow until it starts cycling and burning a bit. Sadly people think the color of the fluid means that it's protection properties have degraded which isn't true. But this is how people think so it is what it is.
Old 02-27-2013, 06:18 PM
Shlooky's Avatar
My Ride: 545i
Thanks Achtung, I am tasking her in tomorrow for inspection. I think it's the coolant as I had to top off about half the coolant container just three days ago.
Anyway I'll find out tomorrow and get it fixed. Will provide an update.in the evening
Old 02-28-2013, 08:17 AM
Howitzer's Avatar
Check the oil filter housing gasket. This is very common to leak. It's usually a 1.5 hour job by a skilled tech. Book time is 3-4 hours though so careful. Might be $350 to $500 tops to fix if that's what it is.
Old 02-28-2013, 11:24 AM
ifilafine2@yahoo.com's Avatar
My Ride: 2005 545i E60 6 Speed Sport Package
@healthservices,classic lol
05 545i e60 6speed
just dropd her off @indy shop for motor oil leak, within a hour the phone call came
upper timing case leak, "big job" indy shop owner says to me
$2800, "ouch" was my reply hahaha >F@*#<
should be ready next monday
Old 03-01-2013, 08:56 AM
Shlooky's Avatar
My Ride: 545i
So here is what was replaced....
1-Oil Pressure Switch
2-Vacuum pump O ring
3-lower and upper radiator hoses
4-Aux Fan switch
5-Aux water pump
6-Valve cover sealing ring (2 of them)
7-Crankcase Vent valve (2 of them)
8-crankcase hose set (cold climate)
Hopefully now it's ok, I have to check it today for any new leaks.
Quick Reply: I discovered an oil leak!!
