5Series.net - Forums
-   -   Humidity Sensor? (https://5series.net/forums/e60-discussion-2/humidity-sensor-16702/)
vffun Oct 3, 2005 07:54 PM
Whenever it's raining outside, I found that if I don't have the A/C on, the front windshield blower will blow hot air while the others are blowing cold air.... Is there a humidity sensor or it's activated by the wipers...
Thanks
Arcadia Oct 3, 2005 08:27 PM
When you're in Auto Mode, it'll defrost the humid in the car. The answer is yes, there is humidity sensor in the car.
eugeneloke Oct 3, 2005 09:10 PM
Auto mode doesnt work too well if it's pouring - i find it tends to get stuffy
Analogs Oct 3, 2005 09:54 PM
[snapback]178992[/snapback]
The humidity sensor actually operates as a glass(surface) condensation sensor that detects and activates the A/C for condensation control on the glass windshield.
The sensor operates by capacitance variance over RH. The sensor operates indiurectly to cover RH in the auto other than for the surface glass condensation. That being surface (glass) versus airborne convective RH in the car.
Peter530i Oct 4, 2005 01:47 AM
yes there is a sensor with the extended AC option. Extend is the one where you can select two different temperatures for driver's and passanger's side....anyway, most of you guys have it....
IMHO the sensor works great. I do not have fogged windows ever. Works perfect
Rudy Oct 4, 2005 04:37 AM
[snapback]179072[/snapback]
Me too. I never fog up...
Ricracing Oct 4, 2005 06:30 AM
I do not have it because im missing the extended AC option. :(
No problems anyway because I'm running the AC all the time:)
vffun Oct 4, 2005 06:58 PM
Good to know!
Thanks everyone!
