HUGE Dissapointment: URGENT Help needed (wheels and tires)
Thanks for all your Help
My Ride: 2008 E60 528i
6MT, Sports Package, Premium Package, Navigation
the gap above the tire will still be there even with spacers. you need to lower it with springs or coil overs
Absolutely true! Considering these http://www.modbargains.com/H-R-Sport...-Series-M5.htm
What would spacers exactly do? How are these installed? Would spacers compromise stability?
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Why were those tyres chosen when the OEM size is 245/40R18?
My Ride: 2008 BMW 550i M Sport
Wheels have wrong offsets. As far as I remember you can fit 245 tire on 8" wide rim. You will need spacers. 15mm on front and 20mm in the rear should work. The gap looks so bad because you have non sport model. Sport suspension sits lower, so coil overs or lowering springs will be needed. GL!
If the 18x8 wheels you bought were offset 20mm to begin with then you could as an option run spacers for the flush look or for a wide track feel for handling etc...All non XI cars are usually et20 in the front and ET33 in the back. M cars are more aggressive and run ET12 and ET 28.
Your rims are probably from either XI or 3 series type rims they look close to a m3 wheel. All those cars run 34 front 37 rear.
For reference the offset is stamped on the back of the wheel ETXX along with size of the rim
My Ride: '07 530Xit, Ty Silver/Black leather, 6MT, Sport, Cold, Nav, PDC, sport seats, square 18
Unless I am mistaken, the sidewall height of a 225/45-18 and a 245/40-18 is virtually identical (within 3mm) so the choice between these two tires will not change the gap size at all. Correcting the offsets with spacers should make it look like a somewhat smaller gap, because the tire will be closer to the fender lip. The gap with the new wheels is actually the same as it was with his stock wheels, but as usual, a bigger wheel with a narrower tire (giving same overall height) always accentuates the look of the gap. Bottom line is that these wheels with spacers will look identical to the correct offset wheels, and tire choices won't change the gap (unless you puton oversize tires), only the width of tread, so final remedy is lowering.
