HUD too low?
My HUD is positioned at the same point above the front of my car as in this picture that the ICEMAN took of his car.
I feel that I have to "look down" too much to see the speed (Nav directions are better because they are positioned above the speed), and yes, I have lowed my comfort seats to be a low as I feel comfortable with.
Does anyone else have the same issue/concern with the position of their HUD?
Has anyone gotten their HUD adjusted to show-up higher on their windshield/screen?
My Ride: E60
I dont have HUD, but I would think it's low by design. I mean, much higher and it may be a distraction? You guys with HUD would know better -- I know that.
Originally Posted by kigerka' date='Jun 9 2005, 09:23 AM
The HUD can be adjusted.? It is adjusted in some wierd areas but it can be done.
[snapback]137916[/snapback]
My Ride: F02 LCI Individual
Model Year: 2013
The factory default is the lowest possible position, since not all drivers are tall.
However, your dealer can adjust the height.
Mine will get moved up when I bring the car in the next time.
[snapback]137965[/snapback]
Model Year: 2013
Originally Posted by Canada545' date='Jun 9 2005, 09:34 PM
[quote name='Iceman' date='Jun 9 2005, 12:52 PM']The factory default is the lowest possible position, since not all drivers are tall.
[snapback]137978[/snapback]
[/quote]![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
I'm allways looking "down" so the dealer moves it up for me.
My Ride: 10 Melbourne Red X6M
I have the same problem but I need it raised because I can't see it. I'm 5'8" but I like sitting low. In the position I feel confortable, the HUD is pretty much un-viewable so if i even want to use it, I have to sit higher. I called my dealer and they said that they were unable to do it. I will have to check again. Are they any possiblities to program it so that it shows the revs like the M5?
David
David
Model Year: 2013
Originally Posted by bleudyno' date='Jun 10 2005, 12:27 AM
I have the same problem but I need it raised because I can't see it.? I'm 5'8" but I like sitting low.? In the position I feel confortable, the HUD is pretty much un-viewable so if i even want to use it, I have to sit higher.? I called my dealer and they said that they were unable to do it.? I will have to check again.? Are they any possiblities to program it so that it shows the revs like the M5?
David
David
[snapback]138039[/snapback]
They can't program it for you.
But they can adjust the height of the HUD. They need to remove the CID. Behind it there is the HUD adjustment. They have a special tool for it.
My Ride: G30 M550i
Model Year: 2018
http://forums.e60.net/index.php?showtopic=2717
