HUD navigation?
Hi!
I've been having a problem with the heads up display on a 535D. Normally, when you used the navigation to guide you somewhere, there would be arrows on the HUD, telling you where to go.
The problem is, after the car has had a tracking device fitted by a shop, the navigation wont show up in the HUD? I've tried going into the iDrive settings and turning it on, but it wont work, and everytime I check, it has turned itself off in the settings menu?
Does anyone know how to solve this?
My Ride: 04 BMW 545iA ZSP, ZCW, HUD, Silvergrau
As far as I know (in USA) Progressive's Snapshot device is optional (although if you want to attempt to get lower rates then that's another story - and dependent on your driving style; if they don't think the data proves your a "safe" driver your rate will go up).
My Ride: 2008 BMW 535xi Purchased 2/2011Sapphire Black MetallicNatural Brown LeatherPremium, Sport & Cold Weather
Where are you that they mandate monitoring and tracking for insurance?
Well I'm from Denmark, and it's because the car is CRAZY expensive here! It was around 265.000 USD when it was new a couple of years ago. So the insurance companies demand that you have a tracking device fitted...
But, do you guys think that the device was somehow fitted wrong, or is messing with the car somehow...?
Esser, Is it safe to assume that the nav screen still provides the proper directions but they won't show on the HUD? That would help to determine if it is a signal problem or just limited to the HUD.
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
Best thing would be to go to the guys who fitted it and ask to temporarily disable it, then you can compare if the HUD-navi is influenced by it.
A tracker is usually a simple device hooked up to an antenna source (usually near the rear of the car to hook up to the mobile shark-fin antenna) and a power source. So in theory there should be no influence to the HUD-navi working.
Perhaps when they connected it, some module started to work erratically (power glitch) or they tried to hook up a tracker which somehow sources its signal from the on-board navi computer and screwed up something there.
