HUD adjustment
Old Oct 11, 2009 | 08:23 AM
phocker's Avatar
Does anyone know how to adjust the settings of the HUD? I'd like to move the display height. I heard the shop could do it, but wanted to save me a trip.
Old Oct 11, 2009 | 09:49 AM
BAK530dat's Avatar
My Ride: 2006 530dAT
Post
Hi
You have to remove the Central Information Display, and you also need special tools to adjust. And you also need access to a DIS tester. So I would leave it to the shop.
Old Oct 11, 2009 | 02:58 PM
aznronin's Avatar
i took mine into my local bmw dealership and they adjusted it under warranty.
Old Oct 11, 2009 | 04:22 PM
JDoug550's Avatar
HUD Adjustment Link - tried it but the vertical adjustment capability is very minimal.
Old Oct 11, 2009 | 04:56 PM
Gene's Avatar
and here's the link to the pdf Rudy posted in the FAQ section RE: HUD adjustment...
https://5series.net/forums/index.php?s=&amp...ost&p=29655
the Link JDoug provided is much better tho...
Old Oct 13, 2009 | 03:38 PM
phocker's Avatar
thanks guys! well i hope the vertical adjustment is good enough.
Old Oct 16, 2009 | 05:00 AM
stanatl's Avatar
When having them adjust the HUD vertical setting be careful that you don't raise it to a point where, at your seat height, the view is faded. When I had mind done, the Tech suggested I be there and sit in the car with my seat set where I wanted while he moved it. There's a point where it fades.
There is not much play in there, but it was enough so that my wife could see the HUD at her seat setting (much higher than mine). At the original setting she couldn't see the HUD images clearly.
Vman33
Mar 14, 2022 04:43 AM
vince_e60
May 26, 2018 10:02 PM
PakiBeamer
Dec 9, 2016 04:40 AM
bestofthebest
Jan 5, 2016 07:47 PM
subieworx
Sep 21, 2015 01:19 PM
