HP Fuel Pump Failure
Yesterday when I was pulling out of a parking lot the engine started to stumble. Turned car off and restarted and all was ok. Today, I had to switch out company cars, so my wife took the 535 to work and on the way home about a block from the house the engine started stumbling again and had no power. (3 times) Now the check engine light is on so I took it to Autozone and they read the code P142e which shows up as a fuel pump failure. I've already had the fuel pump replaced 1.5 years ago and now again the same problem??? Hmmm... glad it's covered under the extended waranty. Now I am curious how long these pumps are supoosed to last...
My Ride: 535i
Sounds like you had one of the pumps they were using before the recall was issued last December. There were two since then, I guess at least now you are getting the latest. Would be a good time to have them check the injectors if they haven't already.
Yes,the injectors were checked and determined to be ok this past May during the last service. Hopfully, this new HPFP last longer...
My Ride: 535i 6-speed
UPDATE: I just received a call from the STEALERSHIP and they tell me they cannot read the code fro the fuel pump problem because of the JB4 software that I have added! They offered to run a fuel pressure check for $265.00 which is non refundable and it may or may not tell them anything. I am starting to smell a lot of POOP here...
I just found out from Burger Tuning that the dealer cannot read the OBD if the JB4 is not set to 0. Ok, I knew it was not detectable in 0 but did not realize it would actually prevent the OBD reading. I could care less if the dealer knows that I have this in my car because the car is not under the factory warranty anyway. I guess the Stealer could try to link the problem back to the software and say they won't cover the fuel pump... Let's hope that's not the case.
I'm sure I will be screwed. When they called after not being able to read they had already looked in the box and told me the spyware wad most likely causing them not to get a reading. He mentioned he took pictures. So I am sure it won't be pretty. He has not said anything about voiding out warranty. Thats probably coming next!
My Ride: 08 535i stock.
wifes car 07 x5 stock
Just a question about this recall, your saying it's a ten year/100,000 mile warranty on just the fuel pump? I knew about the recall but did not know they extended it. Thanks for making this post cause I would never known.
Also Persian,
How do you clear codes once you remove the jb4. Or do you clear codes then remove jb4. I only ask because I also have a jb4 and this would be good to know if I ever need to bring my car in.
Also Persian,
