How will I know if my E60 is overheating????
so lately I have been seeing only two bars it doesn't go any lower than that but still I see you said 3 as your lowest so I'm wondering is having only the 2 bars mean I'm running hot? Granted I live in mid/nor cal & over last week or so it has been starting to get really hot here.
ok thanks, yea no alarm/warning of any kind. I checked coolant an its not low, however there was some, I guess you would consider it run-off but it was dried up on tank and had dried anwhitish color and I remember reading something about this happening in a post while back and if I remember correctly It had something to do with something electronic malfunctioning but have to hunt for post to be positive.
One other question I have is if anyone knows what the average/normal temp. that our transmission's should be showing on secret obd2 temp gauge?
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
you will know when the car gets too hot, a yellow overheat warning and tone will show on DIC.
if it really starts to overheat, a red overheat warning will show.
Example
![](https://duckduckgo.com/?q=e60+bmw+overheat+warning&t=h_&iax=images&ia=images&iai=http%3A%2F%2Fwww.automachi.com%2Fwp-content%2Fuploads%2F2018%2F02%2Fint-featued-what-water-pump-and-how-it-work-06.jpg)
if you don't have an owners manual, get one.
Example
ok thanks, I checked coolant and its still full however I'm unsure when the last flush was or if ones even been done on the car is that something I should look into as a form of preventive maintenance or more something to look into if a problem ever pops up?
Model Year: 2009
Engine: N54
I wouldn't worry about it at all, unless you start having problems. Your coolant should be fine for a long long time.
It's more likely that you'll have to replace the water pump, thermostat, radiator, expansion tank, etc. before long anyway
ok thanks, I was trying to decide if I should flush my coolant system or not, the car is 14 years old with 120k miles on it but I have no idea if it has ever been done before or not, and I do know that something is going on with it because on real hot days after driving my car for awhile when I get home an open the hood there is dried up white spots all over the engine bay and from what I understand the spots are dried up coolant so it is either leaking a tiny bit making it a spray or its coming from the valve on the expansion tank but from location of spots, since there are all over, its hard to say whats the cause, I will take a pic later on today.
My Ride: E60 550i
My Ride: E60 550i
This is funny. When I was about 14 I saw in forums people saying google is your friend.
Now is my turn to say YouTube is your friend.
https://www.youtube.com/watch?v=G5WfCfcmx4o
Best wishes,
Brian
jasonkhasnofriends
04-27-2015 12:41 PM
