5Series.net - Forums
-   -   how/where do you add brake fluid to a 535? (https://5series.net/forums/e60-discussion-2/how-where-do-you-add-brake-fluid-535-a-104968/)
e6t Oct 6, 2010 02:39 PM
just started the car after a long period of rest and idrive tells me it needs brake fluid... cant find a diagram of where to add the fluid.
anyone?
thanks!
healthservices Oct 6, 2010 02:55 PM
anyone?
thanks!
You can do a search in the DIY section but here is how to get to it.
http://forums.5serie...l__bleed+brakes
most likely if your fluid level is low, your brake pads are too.
response_surface Oct 6, 2010 04:08 PM
you'll have to pull the engine out first.....well not quite but you'll need to remove a large piece of moulding around the windshield wipers and remove the cabin air filter cover
e6t Oct 6, 2010 04:16 PM
good lord, apparently so.
idrive shows 15,000 miles to service.
healthservices Oct 6, 2010 05:01 PM
iDrive is just a guide, but I would just take a peek threw the spokes.
e6t Oct 6, 2010 05:17 PM
Look fine to me... Car only has 10,000 miles on it.
Can the service indicator be reset?
healthservices Oct 6, 2010 05:47 PM
Yes, but remember there has to be a reason for the level to go down. The fluid does not just disappear, unless there is a leak. It either takes up fluid behind the piston as the piston moves the brake pads forward, or it is leaking.
Veight Oct 7, 2010 08:08 AM
anyone?
thanks!
Yes, since you are under warranty, you call your BMW dealer and schedule an appointment and have them find a potential leak. Its free service.
525iEnjoy Oct 7, 2010 08:24 AM
Or the brakes are worn and the piston is going further hence lower fluid level. Like everyone else said. Have it checked its part off the service.
