how/where do you add brake fluid to a 535?
You can do a search in the DIY section but here is how to get to it.
http://forums.5serie...l__bleed+brakes
most likely if your fluid level is low, your brake pads are too.
My Ride: 2005 545i Sport 6 speed Manual
you'll have to pull the engine out first.....well not quite but you'll need to remove a large piece of moulding around the windshield wipers and remove the cabin air filter cover
Yes, but remember there has to be a reason for the level to go down. The fluid does not just disappear, unless there is a leak. It either takes up fluid behind the piston as the piston moves the brake pads forward, or it is leaking.
Yes, since you are under warranty, you call your BMW dealer and schedule an appointment and have them find a potential leak. Its free service.
