how to turn on heater?
ok i feel like a fool for asking this question,
but last night i was reading the owners manual and it has no mention on how to turn on the heater in the car???? it has a whole section on the A/C, but no mention of heat.
so do i set the temp control to say 85 degrees, turn off the a/c button (with the snowflake), and just adjust the fan speed?
but last night i was reading the owners manual and it has no mention on how to turn on the heater in the car???? it has a whole section on the A/C, but no mention of heat.so do i set the temp control to say 85 degrees, turn off the a/c button (with the snowflake), and just adjust the fan speed?
Originally Posted by pipper' date='Oct 21 2005, 02:20 PM
ok i feel like a fool for asking this question,?
? but last night i was reading the owners manual and it has no mention on how to turn on the heater in the car????? it has a whole section on the A/C, but no mention of heat.
? but last night i was reading the owners manual and it has no mention on how to turn on the heater in the car????? it has a whole section on the A/C, but no mention of heat.so do i set the temp control to say 85 degrees, turn off the a/c button (with the snowflake), and just adjust the fan speed?
[snapback]186943[/snapback]
You need only to select the temp.
If you so wish you can turn the cooling AC system off.
My Ride: Currently: E46 M3 -02 Topaz, SMG, HK etc (Will stay).
On order : 530d Touring TiSilver, BlackDakota Leather, M-sport Package, Comfort Seats, Logic 7, Active Stearing, Xenon, BT etc.
My Ride: G30 M550i
Model Year: 2018
The trick to using the automatic climate control is to make adjustments to the temperature dial only. Press auto and dial your temperature. The compressor light (snowflake) will probably stay on but that's okay because it helps to control the humidity in the winter.
Many people who are new to auto climate control systems will adjust the fan speed if they're too cold or too warm but doing that will override the automatic system. If you're too cold, just turn the temp up a couple degrees. If you're too warm, turn the temp down a couple degrees. Resist the temptation to mess with the fan speed...
My Ride: 2005 545i with Sport Pkg, Nav, HUD, Cold Weather Pkg, Rear Shades
You do have to adjust the Vent Setting in the idrive too. Remember you can set it to blue (cold) or orange (hot), by turning the i-drive controller.
Getting cold here in Chicago and had to switch the heater on a few weeks ago. Initially I just turned up the temp, but noticed that the vents weren't blowing hot air. That's when I remembered i need to adjust the vent settings to hot too.
All the time I was in Auto mode. Kinda defeats the meaning of "Auto", but that's the way it works.
Anyone care to confirm this?
My Ride: In a place where the Mercedes density is the highest in the world (no. of MB per square kilometer) I choose a Bimmer, why? because of one thing "The Ultimate Driving Experience"
My Ride:
523i Steptronic, Silver Grey Exterior, Black Interior with Black Dakota Leather and Maple Wood Trim. Chrome Grill, Style 123 rim, Airbags everywhere, PDC, Rain sensor, Auto lights, Moveable front armrest, Advance Climate Control, Glass Sunroof, Auto dimming interior and exterior mirror with foldable functions, Extended Lights package, 6 CD changer in glove box, Power seats with memory, Power adjustable steering wheel, Power rear sunblinds.
Add ons: 123 wheels, chrome grill, K&N Hi flow filter, Eibach Pro Kit, e60.net decal and 24,000km
Past rides:
2001 Nissan Xterra SE
1999 E39 523i
1999 E46 323i
1996 Acura Integra LS
All the time I was in Auto mode. Kinda defeats the meaning of "Auto", but that's the way it works.?
[snapback]186980[/snapback]
My Ride: 2006 525i Jet Black (Base + PDC)
I think the vent setting in the i-drive is controlling the 'fresh air' mixing in...whether you want 'Cold' (Blue) or 'Hot' (Red) fresh air or 'Closed' (White). This is independent of the ACC and only affects the vents on the dashboard.
Therefore even if you set the temp so that heat is coming out, but you had the fresh air turned to 'cold', then you'll still get cold air coming from the vents on the dash. If you do not want the vent to affect your temp setting, the best way is to close the fresh air mix (White).
Hope this helps...
Hope this helps...
My Ride: 2005 545i, Orient Blue, Black Interior, Sport Package, Satellite
