How to remove the CEL(check engine light)
My Ride: 2004 545i, BMW Stainless Steel Pedals, #166 Rims
I recently had my service light come on for being low on brake fluid. I simply opened the hood removed the cabin air filters and added more brake fluid, but the CEL will not go off. I orginally assumed that the brake fluid had a sensor that would turn it off once more was added. How do I get the CEL to come off? can I go through i-drive and turn it off or do I need to buy a computer to do this?
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
are you referring to the warning message for brake fluid, or the actual CEL (check engine light)?
CEL is usually caused by an emissions problem. i highly doubt its due to brake fluid...
My Ride: G30 M550i
Model Year: 2018
Is your gas cap on tightly? I think a loose cap will trigger the light and I think I remember hearing that after the cap is tightened, it might take a day or so for the light to go out (unless a dealer resets it manually.)
Other than that, I agree with jet190rs that a low brake fluid condition probably wouldn't trigger the light...
DavaiLave
08-02-2022 02:16 AM
