How Much PSI??
Old Jun 10, 2010 | 11:33 AM
Ghostteck's Avatar
My Ride: 2008 550i manual
Engine: V8
As the topic says I have 20" DPE st-10 wheels and as everyone has seen I had a blow out during midnight run. I was running front 245/30/20 rear 285/25/20 with 36 PSI all around. right now I have front 245/35/20 and rear 285/30/20 can someone help me on how much PSI is good for 20" rims? I would like to know before this saterday as it is bear mt and my car is in the shop right now being raised and adjusted.
Link to my blown tire....
https://5series.net/forums/topic/996...un-2010-video/
Old Jun 10, 2010 | 11:36 AM
pjinca's Avatar
I run the same size tires as you are now (F - 245/35/20, R - 285/30/20). I am running 40psi in the front and 38 in the rear. A lot of others run near 35 PSI, but since I have coilovers I wanted the tires a little stiffer as well.
BTW, you're a brave man running 25 sidewalls in NYC - eesh, I am not that brave
Old Jun 10, 2010 | 11:54 AM
wanker's Avatar
The specific PSI for any tire size is listed on the driver's side door panel, and is listed in your owner's manual. Depending on the specific tire and typical load of your car (number of passengers etc.), BMW recommends between 32 to 35 psi.
Old Jun 10, 2010 | 12:05 PM
rctmthouse's Avatar
I think those recommended PSI were intended for stock rims, not 20"
Old Jun 10, 2010 | 12:06 PM
pjinca's Avatar
+1 When you go plus 3 on the wheels size the door jam numbers pretty much go out the window.
Old Jun 10, 2010 | 12:17 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
One thing to consider is how fast you go in those tires...
I am actually doing 40 all around.
Old Jun 10, 2010 | 12:28 PM
pjinca's Avatar
Oh also there was a great little article in Roundel a couple of months ago on how to properly adjust your tire pressure, it was focused on auto-x but works well for daily driving as well.
Old Jun 10, 2010 | 02:09 PM
Ghostteck's Avatar
Engine: V8
thanks for all the help guys pjinca your crazy! 20% all around.... then i notice socal lol much better roads then here... yea i got 35/30 now because of the nyc street.. i think im going to put 35-40 all around
Old Jun 12, 2010 | 11:28 AM
BMWRINO's Avatar
40psi all around - wheel/tire size in sig
Old Jun 12, 2010 | 06:01 PM
limbows's Avatar
My Ride: E46 E60
I'm using 35 all round.. Running 30/35 tire.. A bit confort ride with non sport suspension i think..
