How to measure the 0-100 Km/h in an Auto E60?
Old 09-14-2005, 01:54 PM
  #21
Merv the Derv's Avatar
My Ride: 535D Sport Auto
Originally Posted by m630' date='Sep 14 2005, 01:07 PM
[quote name='Evenflow545' date='Sep 14 2005, 12:53 PM']I know there are some rocket scientists on board.? ??
How fast would a 520i do 0-100 kph at terminal velocity?
[snapback]170526[/snapback]
...im no rocket scientist, but fan of physics:
heres a good definition, anyone want to do the math
"....it's really an approximate equation for terminal speed (I say speed because velocity describes both speed and direction).
The two dominant forces in free-falling through the atmosphere are drag and
gravity. (Atmospheric) Drag is due to what we call (skin or surface)
friction. Long story short, the typical formula for atmospheric drag is
D = (1/2)*C*A*p*(V^2)
D is the drag force, in Newtons (or pounds)
C is the coefficient of drag, or drag coefficient, which is unitless
C is often written as Cd where "d" is a subscript
A is the area of the body's surface over which the air is flowing
p is the density of the air, in kg/(m^3) or slugs per cubic foot
V is the speed of the air flow relative to the body which is experiencing
the drag
V is expressed in meters per second (m/s) or feet per second
The units for D is then ( kg/(m^3) * (m^2) * (m/s)^2 ) = kg*m/(s^2) =
Newtons
or ( slugs/(ft^3) * (ft^2) * (ft/s)^2 ) = slugs*ft/(s^2) = pounds
note: a slug is the imperial unit for mass, just like the kilogram (kg) is
the SI unit for mass
note: the density of air is not constant, it changes over time and
location. You can read more about this in the references, below.
The force exerted by gravity is called weight. The formula is
W = m*g
W is the weight, in Newtons (or pounds)
m is the mass of the object, in kg (or slugs)
g is the acceleration due to gravity, in m/(s^2) (or ft/(s^2))
note: I'm using the carat "^" for exponentiation. a^b is "a" raised to the
power of "b", so that 2^2 is 4, 4^2 is 16
note: acceleration due to gravity changes with location. This is often
ignored for problems like what you're describing, but if you double your
distance from the center of Earth, then the acceleration due to gravity is
one-fourth what you felt before.
If there were no atmosphere to slow you down, the force of gravity would
continually accelerate you until you collide with something solid (like the
earth). However, the atmosphere does exists and it retards your motion
with the force of drag. Therefore, the resultant force you feel towards
the earth is weight minus drag (W-D) and when your speed increases to the
point that the drag you feel equals your weight, you will accelerate no
more. This then, is your terminal speed. And the equation to find it is:
W = D
m*g = (1/2)*C*A*p*(V^2)
and we can rearrange this with some algebraic manipulation to get
V^2 = 2*m*g/(C*A*p)
or
V = ( 2*m*g/(C*A*p) )^(1/2)"
[snapback]170528[/snapback]
[/quote]
And I always thought you used algebra to reduce excitment whilst on the job. How stupid of me!
Old 09-14-2005, 01:57 PM
  #22
znod's Avatar
Originally Posted by Evenflow545' date='Sep 14 2005, 04:10 PM
Exactly, M630.? I've crunched your figures, and it appears that a 520i will do 0-100kph in exactly 10.7 seconds while plummeting off a cliff.
Shebs, it's safer to keep doing neutral drops.? ? And, if I'm ever cruising around in my rig out in Cairo and stumble along on your transmission, I'll gladly return it.
[snapback]170603[/snapback]
His car really is slow since, as I recall, it takes a sky diver about 10 secs. to accelerate to a terminal velocity of about 120 MPH when in "standard" sky diving position.
Old 09-14-2005, 02:36 PM
  #23
BetterMakeWay's Avatar
Originally Posted by donv' date='Sep 14 2005, 04:57 PM
[quote name='Evenflow545' date='Sep 14 2005, 04:10 PM']Exactly, M630.?? I've crunched your figures, and it appears that a 520i will do 0-100kph in exactly 10.7 seconds while plummeting off a cliff.
[snapback]170636[/snapback]
[/quote]
So? It doesn't mean it's not fun...remember weight has a word to say and on twisties it means quick times and lots of fun AND it's still a bmw...an e60 if i'm not mistaken
Old 09-14-2005, 04:45 PM
  #24
m630's Avatar
LMAO
Old 09-14-2005, 04:57 PM
  #25
znod's Avatar
Originally Posted by BetterMakeWay' date='Sep 14 2005, 05:36 PM
[quote name='donv' date='Sep 14 2005, 04:57 PM'][quote name='Evenflow545' date='Sep 14 2005, 04:10 PM']Exactly, M630.? I've crunched your figures, and it appears that a 520i will do 0-100kph in exactly 10.7 seconds while plummeting off a cliff.
[/quote]
[snapback]170656[/snapback]
[/quote]Yes, it must be very light if it can't beat a sky diver to 120 MPH. ~(;^) And, you are right it still is a great car no matter how fast it gets to 62 MPH.
Old 09-14-2005, 10:15 PM
  #26
Shebs's Avatar
My Ride: 523iA, 2006, Silver Grey, Black Leatherette Interior, Fine-Wood Trim Poplar Grain Brown High-Gloss, 6 Speed Automatic Transmission with Steptronic, Automatic Air Conditioning with Extended Content, Interior and Exterior Mirrors with Automatic Anti-Dazzle Function (Incl. Folding Function for Exterior Mirror), Electric Front Seats with Memory for Driver, Multi-Function Steering Wheel with Cruise Control, Adjustable Steering Column, BMW Radio with 8 Speakers and CD Drive, Park Distance Control, Universal Bluetooth Cell Phone, Electric Rear Sunblind
Thanks for your gentle comments, you were of great help really and you showed your great knowledge about cars in general .
I did expect people like you making fun of my 520i, but it's ok. I like the car, it is fun to drive. Also, I will be glad to overtake you on any curve due to the the lower weight in front and the better front to rear weight distribution in my car .
And by the way, due to customs and tax issues in Egypt, my 520i costs more than your 545i (my car costs exactly $81,000), so please give me a break.
I never said I was doing neutral drops, but anyways if you want to come to Cairo I'd be happy to be your host (that is if you are ever able to get out of Arkansas). Also, you don't have to return my transmission, I have a lot of friends to do that for me, I won't be waiting for you .
It seems that due to your immense knowledge about the world, you've confused Egypt with other Middle East countries, oil is not the major contributor to the Egyptian economy due to it's scarcity. So you will never visit a rig in Egypt, especially around Cairo as you stated .
Old 09-14-2005, 11:05 PM
  #27
fred1976's Avatar
My Ride: 535d
Just a comment on this thread : how do you measure the time?
I suppose that the best way to obtain a good time is to use a kind of automatic chronometer that stops exactly at 100km/h.
If the time data you provide are realised "manually", meaning you press start and stop, then I suppose you should take into account a human error coefficient (you cannot get as my opinion an accuracy of data of 0.1s when looking at the road and the tachymeter alternatively because this action costs you much more time) and also the neural transmission delay supposing that you have overcome the first problem in any (unknown) way.
Thias said, I suppose you were maybe to pessimistic and in fact your car is maybe having the announced measurements! The best solution is, for me, to forget about this and just have fun with your car when you press the gaz and be pressed against the seat!
Old 09-15-2005, 08:37 AM
  #28
m630's Avatar
Originally Posted by Shebs' date='Sep 15 2005, 01:15 AM
[quote name='Evenflow545' date='Sep 15 2005, 12:10 AM']Exactly, M630.?? I've crunched your figures, and it appears that a 520i will do 0-100kph in exactly 10.7 seconds while plummeting off a cliff.
[snapback]170805[/snapback]
[/quote]
..now now now Shebs, please dont take offense, we were only joking ..im personally looking to get the 530i so im just playing here,...all E60s are great cars and wouldnt put any other owners car down!
Old 09-15-2005, 10:51 AM
  #29
KYRIACOS's Avatar
My Ride: DMS 535d. Titanium Silver on Black leather. M- Sport Package.
Mine cost $91,000 here in Cyprus (total rip off) but still a great car to drive!!!!
Old 09-15-2005, 03:15 PM
  #30
Shebs's Avatar
Mine cost $91,000? here in Cyprus (total rip off) but still a great car to drive!!!!
[snapback]170995[/snapback]
Oh my god! That is a total total rip off. I thought my 520i was the most expensive around the world. Welcome to the Mediterannean sea countries .
Quick Reply: How to measure the 0-100 Km/h in an Auto E60?
