How to measure the 0-100 Km/h in an Auto E60?
Old 09-14-2005, 03:07 AM
Shebs's Avatar
My Ride: 523iA, 2006, Silver Grey, Black Leatherette Interior, Fine-Wood Trim Poplar Grain Brown High-Gloss, 6 Speed Automatic Transmission with Steptronic, Automatic Air Conditioning with Extended Content, Interior and Exterior Mirrors with Automatic Anti-Dazzle Function (Incl. Folding Function for Exterior Mirror), Electric Front Seats with Memory for Driver, Multi-Function Steering Wheel with Cruise Control, Adjustable Steering Column, BMW Radio with 8 Speakers and CD Drive, Park Distance Control, Universal Bluetooth Cell Phone, Electric Rear Sunblind
Hi all,
To have the most powerful start for racing or for measuring 0-100, I do the following:
1. Put the tranny in D, with the DSC on.
2. Press brake pedal with the left foot, while applying throttle with the right foot. My car doesn't seem to be able to rev past 2300 rpm (it is a 520i). Is this normal?
3. Release the brake and get a decent powerful start.
The best 0-100 time I was able to record using this method was around 10.7, although the owner's manual specifies that my car is capable of 9.9.
So I thought of the following techniques:
1. Rev the engine in N, then put the tranny in D. I think this is not good for auto transmission , I never tried this.
2. Disengage DSC. I tried this but it seems to offer less acceleration as the power is dissipated through wheel spinning.
3. Just press the accelerator without holding the brake pedal with left foot. Tried this but the car takes sometime to start moving.
Your comments on the points mentioned above would be greatly appreciated. I really would like to see my car jump to 100 in less than 10 sec.
Thanks in advance.
Old 09-14-2005, 03:15 AM
alaa's Avatar
My Ride: 545i YM2005, Gray exterior beige nascar interior, tiptronic, comfort & active seats, Prof NAV, Active steering, adaptive lighting, professional car telephone, alloy wheels 18" Model 124, run flat tyres and Logic 7 sound system.
I believe holding the brake at the same time while you applying accelerator is not a good idea. I believe it may damage you clutch and/or your auto transmition.
Guys, any idea?
Old 09-14-2005, 03:23 AM
Shebs's Avatar
Guys, any idea?
[snapback]170363[/snapback]
I don't think it would damage the tranny. It is just applying more load on the torque converter. I think the torque converter should be able to handle that easily. However I am not sure that it won't be damaged if I keep doing this repeatedly.
Old 09-14-2005, 03:32 AM
530E60NL's Avatar
I wouldn't do it too much. This isn't too good for your automatic transmission..
Old 09-14-2005, 04:11 AM
billysunshine's Avatar
It is called power braking, and will damage the tranny.
Think about it.
The car is designed with performance in mind, but power braking goes against everything those part where designed to do. The added stress; over time, will destroy your drive train.
Enjoy what you have.
The 1 second difference is nothing compared to what it may cost you finaically.
just my opinion
Old 09-14-2005, 04:20 AM
Shebs's Avatar
Originally Posted by billysunshine' date='Sep 14 2005, 03:11 PM
It is called power braking, and will damage the tranny.?
Think about it.
The car is designed with performance in mind, but power braking goes against everything those part where designed to do.? The added stress; over time, will destroy your drive train.
just my opinion
[snapback]170373[/snapback]
But it would be almost impossible to achieve the 0-100 times quoted in BMW's without power braking. A friend of mine had a MB E320 that was quoted a 0-100 of 7.3 sec. Without power braking he would get 9.5 sec at best. See how much difference?
Now the question is why is it bad for the transmission? It will only apply more load on the TC in my opinion, the rest of the tranny will not be affected.
Old 09-14-2005, 04:50 AM
ls78000's Avatar
My Ride: 530d (Jan 2005) premium pack, pro nav, steptronic
Also be aware that the 0-100 secs in BMW documents are generally for manual gearbox, not auto. You usually "loose" between 0.5 and 1 sec with an auto gearbox.
Old 09-14-2005, 04:59 AM
Shebs's Avatar
[snapback]170384[/snapback]
I am talking about the auto 0-100 time, not the manual. The owner's manual provides both.
Old 09-14-2005, 05:47 AM
ls78000's Avatar
Originally Posted by Shebs' date='Sep 14 2005, 01:59 PM
[quote name='ls78000' date='Sep 14 2005, 03:50 PM']Also be aware that the 0-100 secs in BMW documents are generally for manual gearbox, not auto. You usually "loose" between 0.5 and 1 sec with an auto gearbox.
[snapback]170387[/snapback]
[/quote]
Well. I don't know how these performance tests are done. I think many parameters can influence the 0-100 time such as tyre pressure, fuel in the tank, driver weight , weather, type of road ... I guess it's almost impossible to reach the official value that is probably calculated in the best conditions but who cares ?
Old 09-14-2005, 06:18 AM
BetterMakeWay's Avatar
Originally Posted by ls78000' date='Sep 14 2005, 08:47 AM
[quote name='Shebs' date='Sep 14 2005, 01:59 PM'][quote name='ls78000' date='Sep 14 2005, 03:50 PM']Also be aware that the 0-100 secs in BMW documents are generally for manual gearbox, not auto. You usually "loose" between 0.5 and 1 sec with an auto gearbox.
[/quote]
[snapback]170400[/snapback]
[/quote]
I don't think it's impossible to reach the official value, EVEN MORE i think one can even get better times than the official ones. Anyway i tested my theory on other cars i had and it proven to be succesfull not by much tough. If my 1st car was a skoda fabia 1,4 101 hp (11,3 0-100 official, 10,9 the best i could get) a vw passat 1,9 tdi 4 motion 110hp (12,1 0-100 official, 11,8 best).
Anyway i still have to test in on the beast . 0-100 in 6.5 official and i will test it soon.
I will try the fallowing techinques:
1st. DTC and hit M1 in DS and than off we go.
2nd. DSC off completley, power braking than let go.
3rd. DSC off, and floor the gas in M1.
The thing is IMO the DSC cuts too much time by reducing engine power and applying the brakes. So no dsc imo. DTC is also a bit like DSC so maybe it it best to turn it off also. Just disengage the DSC and carefull with the throttle because also too much wheel spin means lost time. But in a way because all that toruqe i don't feel much wheel spin, i feel instead alot of traction and grip from the wheels.
Results are to come...
Quick Reply: How to measure the 0-100 Km/h in an Auto E60?
