how many different kinds of head lights come in E60
Old Dec 8, 2009 | 01:21 PM
webwysard's Avatar
My Ride: 2006 520D M Sport
if the lights stay on when the switch is on auto during the day when its not dark then ? does it still consider as auto headlights.
Old Dec 8, 2009 | 01:37 PM
BlaSTiWi's Avatar
Which light? The outside (bigger reflector) or the inside (smaller reflector)?
If the inside are lit up during the day its DRL
The AUTO setting will lit up the outside when gettin' dark.
Old Dec 8, 2009 | 01:50 PM
Gilgorm's Avatar
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
When it gets dark enough the 'auto setting' on the headlight switch will turn on both the full headlight system as well as the rear tail lights. If its on, then there is a green light beside the switch that lights up. The sensor is in the windshield side of the rear view mirror.
Mine have sometimes come on during bright sunlight but usually when it is low in the sky. Dirt and snow can trick the sensor into turning on. A long tunnel or shady street can also cause them to turn on. If it bothers you then use the lights in manual mode skipping the 'auto setting'.
Old Dec 8, 2009 | 06:49 PM
joebaggg's Avatar
My Ride: 2013 535i xDrive AW/Black M-kit
Originally Posted by Bimmerchop69' post='1070215' date='Dec 8 2009, 10:24 AM
If you point your headlights at a wall or any flat surface and turn your steering wheel you can actually see your headlights move in the direction that your turning. The funny thing with my car 2004 545i is that the lights only go to the right. I believe my driverside headlight was replaced with a non adaptive head light. However they are both Xenon (about 6000k HID) with white angel eyes.
actually the AHL wont work turning left when standing still or under a certain mph.. i believe 5 or 15 or something. dont ask my why but im sure theres a reason
Old Dec 8, 2009 | 07:58 PM
JW-BENZ's Avatar
Probably something to do with affecting other drives on the road since we drive on the right hand side.
Kasmo
May 7, 2019 03:30 AM
Stranger12
Apr 5, 2015 10:42 AM
ZeZe
Oct 15, 2003 12:58 PM
segovia
Jul 6, 2003 10:33 AM
