How to make turbo louder
Greetings
I recently have been looking online about removing my cowl on my 08 535i to increase the turbo spool sound. I figured it out: on the top of the engine bay, remove the big rubber weatherstripping that goes across the engine bay. This will greatly increase the sound of the turbo inside the cabin. You will only want to do this in dry weather because water can get into the engine bay and water on very hot engine components is not a good mix. |
Have you tried an aftermarket intake? Simply changing from the OEM air box to a cone filter will make a large difference in how a turbo sounds in the cabin.
Originally Posted by derooster
(Post 1561970)
Greetings
Originally Posted by KyleB
(Post 1562014)
You're a brave soul doing this in SoFL! Rainy season is upon us.
1 Attachment(s)
"How to make turbo louder"
Go big or go home.... |
Put a 2Jz into the E60?, sounds troublesome
Originally Posted by CityHuntter
(Post 1562584)
Originally Posted by texasmr2
(Post 1562436)
1 Attachment(s)
Originally Posted by audiophool
(Post 1562626)
That's about the only way to put balls on that Lexus...
