How low will the Car sit if I throw on 17's
Old 03-05-2010, 05:47 AM
devildawg712's Avatar
My Ride: 545 modded the F out
Im driving from DC to CA and I know for sure Im not going to be driving 3000 miles on low pro tires so Im about to close a deal on some 17inch takeoffs from a 535. My question to you guys is if I throw them on will my car sit too low as I am running stock sport suspension?? Keep in mind I will have 2 other people on the car ( and probably a full trunk of crap I will be hauling back home)
should I just go with 18's just to be safe or will the 17s be ok? thanks a lot. Any suggestions
JR
Old 03-05-2010, 06:04 AM
BlaSTiWi's Avatar
AFAIK Your ride height will probably only change a tad bit if you are using recommended 19" tire setup (245 & 275) what changed was the sidewall profile.
When in doubt plug in the sizes and you'll get the diameter measurement = http://www.1010tires...ecalculator.asp
And for a long coast to coast drive you'll be doing and lot more sidewall on the 17" to absorb the bumpy road will help a lot more than the 18" or 19"
Old 03-05-2010, 06:32 AM
Originally Posted by BlaSTiWi
AFAIK Your ride hide will probably only change a tad bit if you are using recommended 19" tire setup (245 & 275) what changed was the sidewall profile.
Yea... thats what I was thinking at the top of my head as far as ride height since the tires will be much fatter. I guess 17s will be fine then and yes... the absorption will be a major advantage and a major adjustment as opposed the the 19s. I'll do a tad bit more research but thanks for the reply man.
Old 03-05-2010, 06:38 AM
nigxdoof's Avatar
You'll be fine man. Dont worry.
I had my 20's on and of course it was higher and I've got Bilstein PSS10's and lowered it. I now have the OEM 138's on and it looks great and no problems with hitting bumps and stuff with people in the back.
Old 03-05-2010, 09:16 AM
Thanks man,
That Def. Makes me feel a little more comfortable. Im just a little scared cuz my bros will be accompanying me on this drive across the country and just those two alone weigh over 500 lbs. LOL.
We're some BIIIIIG Filipino Boys...LOL
Old 03-05-2010, 09:36 AM
redEYEjedi's Avatar
Make sure you get a car bra or something to protect the front bumper!!
Old 03-05-2010, 10:36 AM
Munich77's Avatar
DevilDawg - you might want to consider a clear bra. If you need a good installer in the DC area, please let me know.
Old 03-05-2010, 10:37 AM
Seriously!..or a whole lot of blue painters tape....(hella ghetto)
Old 03-05-2010, 11:33 AM
EBMCS03's Avatar
IF they're off a 535 it should not make a difference. the over all diameter should be pretty much the same for the E60s difference is the sidewall and the amount of rim you see...
Old 03-05-2010, 11:44 AM
got it. well then guess the biggest "difference" I am concerned with is ride comfort. Thanks for the clarification
Quick Reply: How low will the Car sit if I throw on 17's
