how to jack my e60 ?
My Ride: Bmw e60 530i _-_ professional navigation- mystic blue exterior- beige interior-logic7-18 inch rims-active steering-bluetooth-adaptive xenon lights-sunroof-sport steering wheel-comfort seats-tv-pdc
I wanna jack up my rear end of the car but I saw the plastic spots for the jack they are too small I have a scissor jack I wanna use it to jack up the car but I don't know where to put the jack
My jack is the same as :
http://ziyuetools.com/products/Jack/...ceServlet2.jpg
I don't have the stock jack, I have runflats
Rear jack-points are right in front of the rear wheel arches. You can buy pads to better mate your jack to the jack-points on the car.
If your jack can support that much weight, you can also place the jack under the rear differential.
scissor jacks I have two, I will lift the back of the car only using them, can I keep the car lifted on them for one day ?
Model Year: 2015
Engine: N55
I would not trust my car up on the jacks. If they slip you have destroyed the rear of your car.
Buy a pair of axle stands, they are pretty cheap.
+1 scissor jacks can be a bit dangerous and have a higher risk of slipping off the jack pad... You really should invest in a set of jack stands. If you decide to use the scissor jacks I would go slow and not get the car too high before you start the other side. Try and keep it somewhat symmetrical to reduce that slipping risk.
My Ride: 2008 535i:
1992 Camaro RS:
Scissor jacks (non-hydraulic) are not very safe and should only be used as a last choice (replacing a flat tire). Always use a hydraulic jack to lift the car and jack stands to keep it supported - it will be safer for the car and anyone working underneath it.
So many people have died using inappropriate jacks, stands, ramps, etc. that permitted the car to collapse unexpectedly. I wouldn't do it . . . and if you feel compelled to do it, absolutely do not get under the car, even a little bit. It's an easy way to die.
Ok thanks aloot for the help!
Thanks aloot I will have that on mind !
