How Frequently Do You Add Oil?
My Ride: 2009 535i xDrive; Black Sapphire Metallic; Premium, Cold Weather Packages, Navi, PDC, 20% Solargard Tint
So I've got a 2010 535xi with 53,000 miles. I had it serviced approximately 8,000 miles ago.
Now it says "need to add a maximum of 1 quart of oil".
Is something leaking or is that quart needed every 8,000 miles?
Thanks.
Thanks.
My Ride: 2008 535i2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim
Do you see leaks? Anyway, after 8,000 miles just change the oil and filter and be done with it.
My Ride: 2006 530I Sport
My Ride: 2008 550i
My 550 used up more synthetic when it was filled with the OEM oil, about a quart and a half in 10K miles. I switched to my trusted Mobil 1 this time around and am on pace to only use 1/2 to 1 quart in the same mileage window.
I have a 06 530i with N52 motor. I just had to fill it up with 1 qt. of oil the other day. It has about 65K miles on it and I had a oil change about 2-3K miles ago. I plan to change my oil at 70K miles so about every 7.5K miles. I was thinking if I should change my oil to 10-30w since it seems to be burning oil quite fast. Any suggestion if this is a good idea or not and if your N52 motor is burning oil that fast too?
I will get the warning around 1000 miles before its due if I wait. I got into the habit of changing it mid point and I never get the warning now. When I check it at that time, it looks to be just a little away from the max point on the scale.
I have a 2008 528xi with 96,000 miles, I've had it since it had 9,000 miles. I change the oil when the car calls for it, usually 15-19,000 miles. I have to add 1 quart between oil changes. I'm crazy about keeping the engine leak free, so it's not from leaks.
Scott
Scott
