How do you put the E60 550i on 4 jack stands?
My Ride: 550i
This morning I have been trying to put the car on 4 jack stands so I can take off all the wheels at one time, but I don't see anyway of doing this?
Help?
Help?
Once the front end is in the air use that same short 5" piece of 2X4 on the floor jack pad and jack up the rear using the rear differential cover. The 2X4 spreads the weight across the differential cover cooling fins evenly to prevent damage to the fins. Then place the two rear jack stands.
I usually use four jack stands. It's quick and easy:
![Name: FOTA48_zpsf1b6f97b.jpg
Size: 71.3 KB](https://5series.net/forums/attachments/e60-discussion-2/157767d1501282206-how-do-you-put-e60-550i-4-jack-stands-fota48_zpsf1b6f97b.jpg)
If spending any time under the car is required, usually not a bad idea to use jacks as insurance on either side:
![Name: FOT95F2_zpse47c8693.jpg
Size: 50.7 KB](https://5series.net/forums/attachments/e60-discussion-2/157768d1501282206-how-do-you-put-e60-550i-4-jack-stands-fot95f2_zpse47c8693.jpg)
![Name: FOT5A6D_zpsf914b955.jpg
Size: 69.1 KB](https://5series.net/forums/attachments/e60-discussion-2/157769d1501282206-how-do-you-put-e60-550i-4-jack-stands-fot5a6d_zpsf914b955.jpg)
When replacing the automatic transmission with a manual transmission, cribbing blocks proved useful:
![Name: 20130817_144907_zps878c274f.jpg
Size: 119.0 KB](https://5series.net/forums/attachments/e60-discussion-2/157770d1501282206-how-do-you-put-e60-550i-4-jack-stands-20130817_144907_zps878c274f.jpg)
Cribbing blocks can take up quite a bit of space.
Drive the front wheels up ramps, then jack at the subframe with a floor jack. Once the front is on stands (at factory jack points), the floor jack should fit under from the front to jack the diff, then put jackstands at the rear factory jack points.
My 535 is factory ride height and I can't get my jack under otherwise.
https://5series.net/forums/e60-parts...3/#post1516451
Click at the following link and look for post #111. Documentation of the conversion pretty much begins there:
And this is coming from a guy who rebuilt an N62B44 in his driveway, haha
(http://www.bimmerfest.com/forums/sho...d.php?t=731948 if you are interested)
You, sir, are insane
(BMW E60, 545i N62, Engine Removal, Rebuild, Installation - Bimmerfest - BMW Forums if you are interested)
Let me know if any questions. The amount of research I had to do was pretty crazy
One thing to keep in mind is I have not seen aftermarket rings for the 4.8L engines. 4.4 you can buy them from Hastings for like 1/10th the price BMW charges
You can probably get them through goetze in Europe if you can find a contact over there
