How do I replace this bulb?
Old 05-30-2009, 05:52 PM
smoak's Avatar
My Ride: 05' 545i Sport Sapphire Black
So I went to Bimmian.com and ordered the H7 bulb (hope it is the right one). Does anyone know how to replace this light, it is extremely yellow. Is there a DIY. Also I ordered some side blinkers in LED. Is there a DIY for those?
Old 05-30-2009, 06:34 PM
bmdub's Avatar
You're probably gonna have to pull the headlight to change out the highbeam bulb. I had to when I changed the xenon d2s bulb
Old 05-30-2009, 06:37 PM
bespoke1's Avatar
My Ride:
That one's not too hard to get to without removing the whole light.
Old 05-30-2009, 06:42 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
you dont need to remove the light. just unscrew the cap behind the light housing, then i think you just twist the bulb out.
i doubt you'll get much whiter light though, since the drl run at partial power.
Old 05-30-2009, 06:50 PM
Gene's Avatar
Have you checked your manual?
If you are referring to the Halo's..
http://forums.e60.net/index.php?showtopic=36860
The side blinkers, do you mean the side blinkers on the headlight unit or the side fenders...either way..again, your manual is pretty self explanatory and easy to follow...
GL
Old 05-30-2009, 09:17 PM
lorinzo's Avatar
Remove the cap from behind the grill. Twist...
Old 05-31-2009, 07:26 AM
bespoke1's Avatar
My Ride:
Isn't that the flash to pass part of the light?? The one with the triangular tab on the back?? If so, that one is super easy.
Old 05-31-2009, 09:46 AM
smoak's Avatar
Im not refering to the "ring" or halo. Im talking about the piss yellow light that stays on all day no matter what I do.
Old 05-31-2009, 11:39 AM
Gene's Avatar
page 182-84 in your manual is pretty self explanatory...
http://www.e60.net/information/2005_..._Manual_US.pdf
Old 05-31-2009, 12:35 PM
CWS530's Avatar
BMW color codes!
Quick Reply: How do I replace this bulb?
