how do i remove this piece?
Old Apr 10, 2012 | 12:26 PM
roskinc's Avatar
My Ride: coilvers retrofits
Model Year: 2001 and 2011
not sure what this is called, roof trim? im going to wrap my roof in matte black vinyl and want to remove this piece to make things easier, but cant find any info on removing it. all i found was a photo someone posted of theirs missing, so any ideas of removal?
Old Apr 10, 2012 | 12:40 PM
tonyb635's Avatar
Very simple, just start in the back and lift the rubber seal, take a plastic tool so you don't scratch the paint and pry up and then just work it towards the front. It's held in by clips.
Old Apr 10, 2012 | 04:12 PM
tonyb635's Avatar
Old Apr 10, 2012 | 04:26 PM
roskinc's Avatar
thanks! i figured might be as simple as lifting it up, but i wanted to make sure, dont want to break anything. im ready to lay down the matte vinvl...just waiting on my seals to come in!
Old Apr 10, 2012 | 04:50 PM
tonyb635's Avatar
Are you planning to wrap the rails that you're removing? I think you should. It makes the color flow symetrical with the windshield and lines.
Old Apr 10, 2012 | 06:25 PM
roskinc's Avatar
yeah i plan to wrap those rails too. i always think it looks off when people matte black their roof and don't do the rails. them removed makes things a whole lot easier.
Old Apr 10, 2012 | 06:47 PM
SD5Series's Avatar
My Ride: 2007 ★ Alpine White
let me know how you went about going around the Fin (antenna) when your done.
Old Apr 11, 2012 | 01:51 AM
tonyb635's Avatar
I thought long and hard about wrapping and eventually decided to just paint it black. I was just too unsure of the unknown of wrapping in general. My concerns were that I would cut something short and still be able to see the original color below, or an edge some where deciding that it didn't want to hang on the the film and start slightly peeling, or even perhaps shirking properties of the film or time. I guess these things are less likely when you have experience behind you, which I didn't. Don't forget to post up some pics when you are finished!
Old Apr 11, 2012 | 01:48 PM
roskinc's Avatar
this will be my first time wrapping the roof, all those things you mentioned that concerned you also in my head. which is why im going to remove all the seals, even the antenna to avoid having to worry about getting the vinyl underneath the seals. plus i needed to replace my seals anyways, their all eaten up. antenna just gonna remove, and reattach. worst scenario i paint it. i just want to be able to remove it if possible.
Old Apr 12, 2012 | 02:01 AM
tonyb635's Avatar
The antenna will come off but I've never personally tried it. I've heard it it a PITAx10! Perhaps a little heat gun on it? Maybe ask Chris (umnichris) what he thinks about getting up close to the seal area and final prepping to get best adhesion. Chances are you have used RainX or something similar and this stuff is very difficult to get rid of. If you've put it on your windshield more than likely its also gotten on you roof by transfer. You can find a pre-clean solution at NAPA that sells car paints. You can wipe it on and wipe it off with a clean new towel a couple of times. Or, even ask them what they have. That was my main fear to put this on and a few months down the road discover that its starting to peel! I wanted the carbon fiber look and when I finally decide to go with gloss black just decided to paint it. Don't forget to post up the pics and maybe some from your process...
ucsbwsr
26
Feb 26, 2025 08:22 AM
christoepurrr
Dec 15, 2015 10:25 AM
olega_ts
Jul 20, 2015 01:26 PM
aarong15
E39 Discussion
Jul 9, 2015 07:01 AM
kentuckynet
F10 Discussion
Jul 3, 2015 06:14 PM
